Question about Microsoft Xbox 360 Console
Sometimes turn on but wont show up on the screen. other times it just has 3 red rings. When there isn't the red ring, i can hear it turn on and start a game. i just see a black screen with a little bit of static. please someone help. i don't want to spend the money to buy an other 360.
  • 767 Answers
No Problem
This requires a little more intensive seating procedures
before the console can get a x clamp mod . if the G.P.U
chip set not preheated prior to the burn in (over heating the G.P.U.
only ), the success rate drop significantly.But with preheating
and proper loading its about 98%, and the stress test most
be at least 24 hours.
Posted on Jul 02, 2009
    Novelist:
  • 144 Answers
NEVER FEAR!
START HERE: You might be covered. It's worth checking out.
http://support.xbox.com/support/en/us/nxe/repairfaqs.aspx
Q: What types of repairs are covered by the Xbox Warranty?
A:
One Year Express Warranty on Console (Three Years for Three Flashing Red Lights).
Subject to the terms and conditions of this Limited Warranty, Microsoft warrants to you only (the original retail purchaser) that, during the Warranty Period and under normal use and service, the Xbox Console will substantially conform with the printed user instruction materials packaged with the Console.
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Part of the outer ring is coloured red and the game wont work
Yikes! red ring is not good, if the whole ring is red you need to check your AV cables, three sections is the Red Ring of Death and you need to send your Xbox in for repairs(http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/flashinglights.aspx). Off the top of my head I can't remember what the two or one red sections mean, I do know their not as serious as the three. my girlfriends freezes from time to time and red rings, but when we restart her system it all goes away (sometimes it still jams at the Xbox load screen)
Jan 20, 2011 | Microsoft Xbox 360 Console
I have three rings when i turn it on. then when i play the game it will freeze most of the time. when it freezes i know its not the game because the screen will mess up and u will hear funny noises. and u...
If you have the 3 red lights showing it means that the heat build up has got too bad on the GPU and the CPU and you will need to get it fixed, you can send it in for repair or fix it yourself using a good repair guide.
Oct 20, 2010 | Microsoft Xbox 360 Console
When i play xboxlive it will freez then the screen will be green or red then i have to turn my xbox help
If this is what happens each time you use your your console, it might be broken. Does it have any red rings around the console's display? If that's the case, check out these links by Microsoft corresponding to the amount of red rings on your console:
1 red ring
2 red rings
3 red rings
4 red rings
They extended the warranty to three years from the purchase date for the three rings. Give them a call at 1-800-4MYXBOX and see if they can't help solve your problem. Hopefully you're still under warranty. Good Luck!
Jan 08, 2010 | Microsoft Xbox 360 Console
Power button on my xbox 360 flashes red and wont play
That's a Red Ring of Death here's more info http://forum.teamxbox.com/showthread.php?t=472553
Sep 25, 2009 | Microsoft Xbox 360 Console
Third ring turned red it shows E 74
:( Feel Sorry for you. 3/4 of RROD means a SUPERFRIED Xbox. give it to a hobo and say Merry Fakemas!
Sep 06, 2009 | Microsoft Xbox 360 Console
Black screen with white dots moving around everywhere
It is possible to open your Xbox 360 and fix the problem, which isn't recommended, but there are many tutorials, but if it is not 3 red lights then you don't have the Red Ring of Death. If the whole ring around the Xbox 360 is red then this means that either the Audio-Video cable is not connected properly, or the Xbox 360 is not detecting it. You can try cleaning the AV cable or you could try buying a new AV cable. The easiest way to decide on what you should do is go to:
http://support.microsoft.com/default.aspx/kb/906652
That is the specific page for your problem and should give you a solution, and if it does not, then you should be able to contact Microsoft, and if it is still under manufacturer's warranty, then they should be able to fix it for free.
I hope I helped! ~Flascher
Jul 16, 2009 | Microsoft Xbox 360 Console
Xbox 360
check your av cable. if its set to hdtv it wont show up on your screen
Jun 19, 2009 | Microsoft Xbox 360 Console
How do you start the lawn mower on imagine babyz nintendo ds?
Put the stylus on the red ring and make short quick strokes to the right. With each stroke you will see the cord pull out and the ring will turn green. I did this about 30 times, then finally i used my finger instead of the stylus and is started up on the third try.
Dec 22, 2008 | Nintendo DS Lite Console
3 red lights, no error screen
you are one of the luck millions to get the 3 red ring of death your xbox is done good think that xbox is offering to replace the console free of charge to those that have that problem so send it back to xbox
Sep 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
64 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
