Question about HP (D7580-60003) Motherboard
HP Media Center M8000. Network card bad, must replace motherboard
I have a HP M8000 Media Center desktop PC. Had it for 16 months. Network card went bad. HP says Network card is integraded onto the motherboard and it will cost $349 to replace the motherboard. What a rip off that is. Anything goes bad and you need a new motherboard? Tried to get HP to stand behind their product, but can't get anyone outside of India to help. Everyone is reading for a script that they can't help. Apparently, after one year, the thing becomes a doorstop. Never had this problem with Gateway, IBM, Dell, Asus, Toshiba systems. Would never buy another HP again. Feeling angry and ripped off. Want to tell everyone to avoid HP products.
  • 615 Answers
Hello Friend,
here is the solution.
Buy New good Network Card Like D-Link or other cost about (10$-15$) install it on pci slot.then install drivers.so now u r system with new working Network Card.
if helps Rate the solution
Posted on Jul 02, 2009
I get no signal on my lcd when I start my m8000 hp pc desktop
There is no communication to the video card. Try checking cable. Reconnect. Make sure monitor is set to correct input, like VGA, DVI, or HDMI. Reseat the video card, and if still nothing, test with another video card.
Oct 04, 2012 | HP (D7580-60003) Motherboard
Can I install pci-e X 16 2.1 video card onto my HP Pavilion Media Center m8400f PC
Its a slot distribution both 2.0 and 2.1. 2.1 is a bit faster as it leads with version. You can install any VGA card that supports it but keep it in your mind that more heavy vga card will require more power. So, you power supply should be heavy and should bear more power for your card as well as your system.
Sometimes, it require to change the power supply as well.
best of luck!
Mar 17, 2012 | HP Pavilion Media Center TV M8400f Pc PC...
My HP Media Center PC m1180n had been running fine. I just went to shut it down and after it powered off, I saw a spark come from inside the tower. No there is no power to the PC. Any help would be...
I've had this happen and was able to resolve by removing the power cord for about a minute.
If still nothing, remove the side panel and inspect the motherboard for melting or charring. If you see some you will need to replace the motherboard, if none is present, start by replacing the power supply. Still nothing then it's motherboard replacement
There is a possibility the spark fried more than just the motherboard.
Comment back if you need clarification or more help.
Sep 14, 2011 | HP Media Center m1180n PC Desktop
HP Pavilion a120n was working great until a few months ago when it appeared that the monitor went out. I tried two different monitors and get NO VIDEO OUTPUT messages on the screen. All the connections are...
Do u have a graphics card in the pc? If you have then disconnect the video cable from that and connect the video cable with the default vga port of the motherboard and check. if there is no graphics card then the integrated graphics card of the motherboard is damaged. that means motherboard is needed to be replaced.
Feb 17, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
I need the part number for an HP Media Card Reader to fit an HP DC5000M.
» HP 16-in-1 Media Card Reader with PCI Card - Overview - c00604206 s.gif Overview for HP 16-in-1 Media Card Reader with PCI Card
» Ricoh Media Card Reader Driver - HP Business Support Center s.gif Version 2.13.00.05 - This package contains the Ricoh Media Card Reader Driver for the supported notebook models and operating systems. The Ricoh Media Card Reader driver provides ...
» Ricoh Media Card Reader Driver - HP Business Support Center s.gif Version 2.14.00.05 - This package contains the Ricoh Media Card Reader Driver for the supported notebook models and operating systems. The Ricoh Media Card Reader driver enables the ...
» Ricoh Media Card Reader Driver - HP Business Support Center s.gif Version 2.13.00.05 - This package contains the Ricoh Media Card Reader Driver for the supported notebook models and operating systems. The Ricoh Media Card Reader driver enables the ... » HP 16-in-1 Media Card Reader with PCI Card - Overview - c00604206 s.gif Overview for HP 16-in-1 Media Card Reader with PCI Card
Apr 12, 2010 | HP DC5000M PC Desktop
Had a power outage, now my HP media center will not turn on.
Sometimes when this happens the motherboard shorts out. You will need to replace that.
Jan 22, 2010 | HP Media Center Photosmart PC (M7160N) PC...
My HP media center edition m7330n desktop will not power up (won`t stay on), The power button light flashes every 2 seconds from blue to orange & no power at usb ports. Any advise on what went bad or...
Before doing anything try to get the following tested,Processor,Power supply,Memory,also remove any cards installed including modem.Look for physical damage(ie) Brown substance coming from capacitors on board all capacitors should be flat on top if they show rounding or a hump over the top the MotherBoard needs rplacing!
Aug 08, 2009 | HP Pavilion Media Center TV m7330n...
Blank screen; Unresponsive computer, & three beeps in succession
2 short beeps and 1 long beep (repeats 5 times) = Unable to initialize video or video card required but not installed. Sounds like the card may have gone down
Jun 19, 2009 | Intel Desktop Board D845GLVA...
HP Media Center m1195c PC
It's a rather indepth process and is usually just easier to replace the computer.  Motherboards have many different adapters / slots / options.  If you're meaning to replace the motherboard and processor cpu, it'd be best to buy a package deal from newegg / tigerdirect / etc.  To be able to use your other components, you'd have to make sure the new motherboard has the same type memory slots, video card slot, etc.
Sep 22, 2008 | HP Media Center m1195c (PJ475AA) PC...
Hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Jun 27, 2008 | HP Pavilion Media Center TV m7330n...
HP (D7580-60003) Motherboard Logo
1,660 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
