Question about Dell Inspiron 1501 PC Notebook
Wont work my dvd/cd-rw wont work I dont know how to find it on my laptop and it don't eve open by pushing eject is it a way that I can test it to see what the problem is
  • 34 Answers
Hello there,
I would recommend removing the DVD drive, cleaning the electrical contacts with a clean dry tooth brush. then insert and remove the DVD drive unit from the laptop a few times (to clean tarnish from the contacts). If that does not work order a new drive from Dell.
Jason
Posted on Jul 02, 2009
  • 56 Answers
Right click on dvd drive on my computer then eject the dvd drive,,,,,,,after that
open bios setting and check device configuration
I have acer 4315 i dvd rw drive is not working so i want to chenge ih. but i dont know hoe tow to remove or open it? pls help me
Hi, if you dont know how it remove or install it, then no need to experiment. But you can solve it . Just purchase a USB suppoted DVD RW and install throgh your USB port of your Notebook. THis is very simple and so easy.
Best of Luck!
May 09, 2011 | Acer Aspire 4315 Notebook
My pc drive wont open Help!!!
Is the cd/dvd? Look carefully on the front, you'll see a tiny hole just below the Tray (usually beside or above the eject button), take a straightened paper clip or a long needle and push inside the hole while you press the eject button, push it inside until it ejects out.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
Wont eject cd
there is a safety release in all disk drives take a paperclip and push it into the small hole on the face of the drive and the drive should pop open
May 12, 2009 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
My lg external drive wont open what to do?
Dear lovableblond,
Please try to use the EJECT button from the software, or from My Computer, right click over the driver, and choose EJECT.
I hope this was helpful.
Have a good day.
Regards,
W.
Mar 21, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Sep 16, 2008 | Computers & Internet
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Dell Inspiron 1501  PC Notebook Logo
107 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
