Question about Traulsen Refrigeration 48'' Wide x 24'' Deep Reach-In ''Ultra'' Wine Refrigerator With 2 Clear Blac...
Why are there ice crystals all over my food it's a new fridge
  • 232 Answers
Probly cold control model # helps
Posted on Jul 02, 2009
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
Ice crystals on food in fridge
What is your temp in the fridge? Check that your door is closing all the way. You have several air vents along the middle of the back way, are you getting the ice crystals of food right in front of the air vents? If that's the case then that is also the problem. Right in front of the air vents is where air from you freezer enters the fridge. I would start with checking the temp in your fridge though.
Mar 14, 2013 | Amana Refrigerators
Freezer is running constantly. ice crystals formed on outside of packaged foods. food is still frozen.
the door was left open,if you find frozen water droplets on the food packages or ice crystals it forms from the warm air coming in,make sure all the packages are pushed in and not hitting the door and you can tilt the fridge back a little so the door will close with a slight push.also check the ice shout door and make sure no air is leaking through it,you'll know you'll see all ice around it.you can check the condenser coil and condenser fan to see if it needs to be vacuumed,the machine will run longer if the coil is clogged with dust or if the fan isn't blowing,the coil should be cleaned every 6 to 12 months.hope this helps but it sounds like the freezer door was left open.
Sep 06, 2011 | Frigidaire FRS23KF7AB Side by Side...
Ice crystals in food bags
shows that you have food that is still warm/wet inside the wrappers.they are frosting up inside the bags.....will cause frezer burn if kept too long....
May 17, 2010 | Freezers
My Westinghouse side by side frost free fridge freezer is freesing the food in the fridge and there is frost on the items in the freezer please help
Can be anything from a damper / cold control issue to a to cold freezer. As for the frost on the food items in the frzr. Most of the time it is normal, especially when the items are in bags or loosely wrapped. Air is the culpert,
air is a gas...at room temp you can't see it. As it cools it condenses to a liquid, as it gets colder it frosts to ice crystals. Vacuum pak or rap tight in plastic and then zip lock removing as much air as possible.
Mar 08, 2010 | Refrigerators
In the freezer food is getting ice crystals on it
Do you mean in the freezer or fridge?
Either way, it looks like you have a fault defrost sensor of a bad thermostat.
Nov 07, 2009 | Refrigerators
Frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
May 20, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Freezer compartment not cooling
Di a total defrost and remove the back wall cover from the freezer. Look for ice buildup in the cooling fins. If the air channel is blocked, you won't get proper freezing.
Mar 23, 2009 | GE Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Furniture Logo
235 people viewed this question
Top Traulsen Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Traulsen Furniture Expert? Answer questions, earn points and help others
