Can this washer be a stackable?
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
SOURCE: GE Front load washer - cannot unlock door
manual lock release is located inside front panel. remove lower kick panel and reach up on latch side and feel for plastic tab hanging from lock asm. pull down.
