Question about Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE
What should I do if my water dispenser just stopped working. Could it be a problem with the filter which is fairly new or would it be the water line itself? I know that ice is still being made so the water supply is there but it won't come out. I can hear the motor or pump when I press the dispenser button.
  • 232 Answers
Waterline behind veggie drawer could be frozen frige too cold
Posted on Jul 02, 2009
4 Suggested Answers
  • 4 Answers
SOURCE: ice maker dispenser
i own a similar model for 2 years now and have had no problems with it. maytag is better than kenmore sad to say
Posted on Jul 10, 2008
  • 58 Answers
SOURCE: water dispenser quit.ice maker works fine you can
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Posted on Sep 16, 2010
SOURCE: The ice maker makes ice
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Posted on Dec 01, 2011
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Inside filter water dispenser suddenly stopped working. New filter removed and no working with or without filter . Water line is fine. Ice maker works.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Mar 18, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Monogram ZFSB26DRSS- water dispenser problem
Disconnect the water line at the water inlet valve on the back and try the dispenser to see if water comes out there and see if you hear the valve work. If the water comes out here then the problem could be the filter. The mesh screen in the water inlet valve could be stopped up. Disconnect the water supply line to see the screen. You may have to remove the cardboard backing to see the valve on the back of the freezer.
Oct 05, 2009 | Refrigerators
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE Logo
271 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
