Question about Nokia 9500 Communicator
Non running of web
The web kotak securities.com is required JAVA VIRTUAL MACHINE which is not installing in my Nokia 9500 communicator, what can i do. Above website is opening but when i place order nothing to do.
I have been forgot my phone lock of Nokia 9500, did you can found it for me?
If you forget the security code means get the master reset code for your nokia mobile, because does not remember security code you have to reset your mobile its a only way to use the mobile, so get the master reset code for your Nokia model mobile from this site Unlocking4free.com, it has the best services for the master reset code for your nokia mobile.....I hope this may helpful to you.........
Apr 10, 2011 | Nokia 9500 Communicator
Machine will not show graphics after working properly for 15 minutes.
This course uses  (Java applets  (Suns' Java technology)  In older version of Microsoft internet Browser the Microsoft Virtual  is already installed in your machine.   In newer version of windows installation, the Java  is  not install automatically.  In most cases, now you must install the Java separately into your machine  http://java.com/en/index.jsp  (download free Java software)
DursulQuran is also available in "Printed version", in theory does not require a computer and the course may be follow independently by using a booklet.   In addition,  the sound of each lessons have been recorded that may be run from stand alone CD player as well the audio cassettes.   The course material may be downloaded freely from this site.   The printed material are prepared in Acrobat Pdf. format and easily printable on 8.5 x 11 paper.  the sound clips are in MP3 format that can be burned into a audio CD (and latter transfer into an audio cassette) as well as run in your hard disk.
Obtain Printed version click here
Dec 02, 2010 | GPX Audio Players & Recorders
How can i installed java software
Java capability for mobile devices is integrated by the device manufacturers. You need to check with your device manufacturer about availability of this technology in your device.
KVM, the virtual machine for mobile devices, is the counterpart of JVM (Java virtual machine). It is used to run applets and applications written with Java technology on mobile devices. KVM must be installed by the manufacturer. It is NOT available for download or installation by consumers.
Nov 04, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
The yahoo games is not loading the applet why is that
JavaScript are fully enabled in your browser. Follow the steps below for your browser:
Netscape 4.XX or newer for Windows, Mac, or Linux
Click "Edit" in the menu bar, and then select "Preferences."
Click the word "Advanced" and put checks in the boxes next to "Enable Java" and "Enable JavaScript."
Internet Explorer 4.XX for Windows
Click "View" in the menu bar, and then select "Internet Options."
Click the "Security" tab.
For the Internet Zone, be sure that the Security level is set to "Medium" or below. (If you 've chosen to customize your Security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You'll want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Next, click the "Advanced" tab.
Scroll down until you see the subheading "Java VM."
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you've checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Internet Explorer 5.XX or 6.XX for Windows
Click "Tools" in the menu bar, and then select "Internet Options."
Click the "Security" tab. For the Internet zone, be sure that the Security level is set to "Medium" or below. (If you've chosen to customize your security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You'll want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Note to Windows XP users
By default, the Windows XP operating system comes with the Internet Explorer 6 browser without the Java Virtual Machine (JVM) installed, which is required to run Java programs such as Yahoo! Games.
If you install Windows XP over an existing installation of Windows that already has Internet Explorer with a JVM installed, then you should be able to play just fine.
At this time, Microsoft no longer provides a download of the JVM if you do not already have it installed. You're welcome to contact them for information on where to find and download this program.
However, you have the option to download Sun's Java plug-in by visiting
http://www.java.com/en/download/help/aut…
Sun is the creator of Java, and their plug-in will allow you to play Yahoo! Games.
Internet Explorer 4.5 or 5 for Macintosh OS 8-9
Select "Edit" from your menu bar and choose "Preferences..."
Then, click the "Java" bullet within the Web Browser section.
Make sure that the "Enable Java" box is checked.
Internet Explorer 5 for Macintosh OS X
Select "Preferences" from the "Explorer" menu.
Select "Java" from the left navigation bar.
Place a check-mark next to "Enable Java."
You may also want to clear your cache and restart your browser.
If you continue to have problems, double-check your computer's compatibility with Yahoo! Games. Source(s): Yahoo games help page
Oct 19, 2009 | Yahoo Mail
Nokia 9500 get restart when click Internet Broser / WLAN setting
Your firmware is ANCIENT. If you have installed Nokia PC suite in your PC connect your (fully charged) phone and click on Software update. If don't have it, then go to Nokia web and download it. YOU NEED FIRMWARE UPDATE.
Oct 16, 2009 | Nokia 9500 Communicator
Not able to play POGO games on My laptop. Has to do with Java/Vista anyone else having this probblem
Install Virtual java machine on your system (last version) Install Flash player (last version)
Jan 28, 2009 | Microsoft Internet Explorer 7
Lost my phone W550I
Greetings.
Its not advisable to post your imei. Pls inform your service provider about this so they can give you advice as to how to recover or at least disable your sim/phone.
Jan 12, 2009 | Sony Ericsson W550i Cellular Phone
Nokia 9500 Communicator Logo
62 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
