Question about PC Chips P23G Motherboard
My pc problems
im berdon of philippines, at 1st my pc has 1gb of ram and my OS is Vista. nad now i upgrade my ram into 2 gb ang i change my Os to XP pack 3. and the problem is my pc is always restarting. could you help me pls.
  • demsag Mar 09, 2009
    I have the same problem, but what kind of power supply is the recommended?
Reset your cmos, use default bios config
Posted on Mar 21, 2009
This was also a problem with one of our computers. The same case until we changed the power supply. The power supply installed was factory defect.
Posted on Dec 10, 2007
  • 4 Answers
Maybe something is wrong with your power supply. If power supply get old, it will restart the computer by itself. Try to borrow a friend's power supply and test it out.
Posted on Nov 09, 2007
Emachines e370 Can you increase the RAM to 3 or 4 GB by replacing with 2GB DDR3 ram modules from 2 total (2/1GB modules without damaging laptop.
If you run a check with mr memory, that will tell you the maximum RAM useable. You may have to instal a 64bit version of your OS otherwise anymore RAM will be unused.
Oct 09, 2015 | eMachines Computers & Internet
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
Hi, im using vgn cr23g. i upgraded- the ram from 1GB to 4GB. Then i upgraded to Vista (Service pack 1) as advised by Windows 7 Upgrade Advisor. Now i want to upgrade My OS from 32-bit Vista to 64-bit...
I have checked the specs of your PC notebook, I can see that you can upgrade the OS of your notebook to windows 7, because your PC passed the requirements for the windows 7 OS.
I hope you have a great day.
Jul 03, 2011 | Computers & Internet
Do this model supporsts win xp service pack 2
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
I have a ACEer 5315 model no ICL50 running Windows Vista. To say Vista is **** is an understatement. I want to switch to Windows 7 but guess I will need a lot more RAM for this. Can I upgrade Ram on this...
I recommend that you switch to Windows 7 without upgrading your RAM. Windows 7 is a lot faster, better and uses less RAM than Vista. Recommended RAM for running Windows 7 is 1GB but I have installed them on a Centrino 1.5GHz with 768Mb of RAM and they run perfectly.
So make the upgrade to Windows 7 anyway and if you feel that you need more power then you can get more RAM.
Also, download Windows 7 upgrade advisor to check if your pc is compatible. Download upgrade advisor here.
Feb 06, 2010 | Acer Aspire 5315 Notebook
I am using a laptop aspire 3683 wih 512mb ram. But my computer running very slow. Can I upgrade the ram for 1gb. Please let me your suggestion. Thank you.
Yes, you can upgrade it to 1 GB RAM.But I recomend you to change it to 2 GB RAM (two 1 GB RAM).It will boost your performance tremendously.
Consider1 GB RAM with 600/666 Mhz.
Dec 31, 2009 | Acer Computers & Internet
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
Home Premium / Business / Ultimate
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
Jul 11, 2009 | Microsoft Windows XP Professional
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
Sep 18, 2008 | Intel D101GGC Motherboard
Intel 845 GVSR drivers for windows vista
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Acer Aspire 5315
I have a friend who has an Acer Aspire 5315 running Vista and it was pretty slow right out of the box with 1gb of ram. I upgraded his Ram to 2gb and it ran moderatly faster and smoother. Vista is a demanding OS because it's so graphical in nature. Windows Vista requires more ram then XP plus a better CPU to run smoothly. His had a 1.6ghz Celeron which is not that great of a CPU to begin with but uping your ram will usually up your performance a few degrees. Be careful with cheap ram it can run hot and unstable. Make sure go with a name brand PNY, Corsair, Kingston, etc. Don't just buy House ram (generic) because it's cheap. It's not worth wasting your money on junk ram.
Hope this helps. M~
May 01, 2008 | Acer Aspire 5315 Notebook
PC Chips P23G Motherboard Logo
95 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
