Question about Compaq (153515-001) Touch Pad
My touchpad is not wrking at all. Then I reinstal
My touchpad is not working at all.
I reinstal the thouchpad driver for my compaq (presarion M2000) laptop but it still wont work at all.
What shell I do?
Thank you
    New Friend:
  • 47 Answers
You should send the laptop back for replacement if it's under warranty. Bad touchpads seem to be pretty common nowadays, on my HP DV5 which is 3 weeks old it has failed on the 4th day. It does not bother me though, as i have bought a mini USB mouse for $5 and it is much better than the touchpad anyway.
If you'd ask me, i'd say just buy an USB mouse, it's much more practical.
Posted on Jul 02, 2009
  • Th3_uN1Qu3
    Th3_uN1Qu3 Jul 03, 2009
    Update: I have repaired my touchpad. It was the heat that made it stopped working, but the actual fault was caused by something else:
    The ribbon cable connecting the touchpad to the motherboard was bent too sharply at the factory and it broke. Since it was long enough, I used an X-Acto knife to cut the broken part off, and saved the blue plastic tab. I placed a thick plastic sheet over the touchpad area so i don't scratch it, laid the ribbon cable on it and with 180 grit sandpaper slowly grinded at the plastic to get the wires exposed. When i got enough length of wire i plugged the cable back into the connector and used the original plastic tab to hold it in place. It worked. I then put a drop of glue on the connector and put the laptop back together.
    Only attempt this if you're brave enough, have very good eyesight and lots of patience.
My touchpad won't work on a compaq presario CO50, button is on, but on working?
Try a restart if that doesn't work, connect a usb mouse and go to the device manager and see if the drivers for the touchpad are installed.
If they aren't, go to http://www.hp.com and input your model number into the search box, there will be a place to download the touchpad drivers. Install those and your touchpad should be working.
Mar 07, 2011 | Compaq (153515-001) Touch Pad
Asus Notebook A70AB touch pad not moving pointer at all, what could be the problem?
you might have pressed the small button above/below the thouchpad which deactivates the touchpad..
try to press the button again to activate it..
if this isnt the case then try reinstalling the touchpad drivers
Feb 28, 2011 | ASUS Eee PC 900 Notebook
Spilled coke on touchpad.......not working. turned off. what to do?
if xp
1.start > control panel > mouse
2.select hardware , check thouchpad driver if see
select properties > driver > uninstall and reboot
after reboot .. touchpad driver install automatically
please let me know this is usefull
Jan 06, 2011 | HP Pavilion dv6000z Notebook
Touchpad Problem
Hi, Check the link below and update the touchpad drivers..
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=96307&prodNameId=97136&swEnvOID=1093&swLang=8&mode=2&taskId=135&swItem=hb-12900-3
However you can also check and update to latest BIOS for your laptop.
Also check the Power options and check under plugged in and Battery options to know what is the status of the touchpad(Mouse).
I hope this should work.Plz try
May 17, 2010 | Compaq Presario M2000 Notebook
NOTE BOOK PRESARION C780EE, MIC IS NOT WORKING WITH XP
Goto to Hardware section under MY Computer and reinstall the driver.
Aug 28, 2009 | Compaq Presario 700 470024-192 Notebook
A shortcut or way to disable touchpad preasario m2000
You could disable it in Device Manager, but that has the downside of leaving you in a lurch if you are ever without your external mouse.
The latest drivers from Synaptics include a feature called "HandCheck" that will guard against unintentional movement when you are typing and your palm or other broad part of the hand is in contact with the surface.
http://www.synaptics.com/support/drivers (see the link for Features to get a full description).
But I saved the best for last. A little hotkey utility that does EXACTLY what you want: http://www.notouchpad.com/
There's a free trial, but it'll cost you $4.95 if you want to keep on using it.
Good Luck!
Jun 05, 2009 | Compaq Presario M2000 Notebook
Drivers missing for compaq m2000
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=fr&cc=fr&lang=fr&os=228&product=433559
All the driver's for audio and graphics should be here for presario M2000
Dec 14, 2008 | Compaq Presario Notebook
Sound drivers problem
HP offers all their drivers at their website, And your best bet would be to reinstall the drivers for it.
Nov 25, 2008 | HP Compaq Presario M2000 Notebook
Compaq Presarion C52TU
give me the details of the driver so i can give you the driver
Oct 27, 2008 | Compaq Presario 700 470024-192 Notebook
Touchpad on Gateway Notebook
Try reinstaling the touchpad's drivers!
If does not work, check if it has been disabled or not (in "device manager" ) If so, enable it , and it should work.
Jan 16, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
626 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
