Question about Apple MacBook Air
No Sound From Internal Speakers
Sound works when speakers or headphones are plugged in. No sound without them. I know the internal speakers work because I can hear the internal bong when it is booting up.
Tried so far - rebooting; rebooting with speakers in the jack then removing; removing battery; inserting a bobby pin, q-tip half, paper clip and plastic tube of a pen and "wiggling" them around. Not sure if I'm wiggling properly though.
Still getting the same thing that no device is selected. Can someone give me more specific wiggling instructions?
  • bridgettemei Jul 02, 2009
    This is for the normal 13" MacBook, not the Macbook Air
  • 50 Answers
Go to prefrence pane select sound then output bar and arrange the volume labeling , can you hear some sound.
Posted on Aug 03, 2009
The sound has stopped working on our GeoSafari LAPTOP No. 8545. Help!
Hi Lisa,
What operating system are you using?
Check that sound is enabled in both the operating system and BIOS.
Check that you have the volume turned up.
If you have an external set of speakers, try plugging them in and see if you get sound. If the external speakers use a power supply, make sure you have the speakers powered and turned on. Computer speakers almost always require power to run the internal amplifier. Computers sound output is so low that regular speakers can not be used. Also, if you have a set of headphones from an iPod or similar device try the headphones. Headphones are sensitive enough to work without power.
Aug 06, 2012 | Computers & Internet
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
I cannot get sound from my internal speakers on dell d600 latitude. Headphones work and sound comes out of internal speakers briefly when pulling jack plug out? So I know they work but just cannot get...
This sounds like a defective audio port. In normal operation, plugging in a headphone plug breaks the connection to the speakers. On your laptop, when you pull out the plug it makes a connection, but only briefly. Unfortunately the audio port is built into the system board. I don't think you will find a software fix for this problem. Your best bet is to get a USB sound device for external speakers.
Apr 27, 2010 | Dell Latitude D600 Notebook
Sound only works with headset. No longer comes
If the sound is working through another device then it seems that the internal speakers are bad. Because if the sound card was bad you wouldn't have any sound whatsoever, same goes for drivers. Probably just some bad speakers. If you have some other external speakers try plugging them into the headphone port and see if that helps.
Mar 08, 2009 | HP Pavilion dv6000z Notebook
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
Sony VAIO VGN-CR23G Sound
i have sony vaio VGN-CR23G. i formatted this xp sp2now the sound driver is not installed on my machine. no audio output m getting........what to do..??
Sep 20, 2008 | Sony VAIO VGN-N130G/W Notebook
My internal speakers have sound when headphones are used but no sound when they are used without headphones
my frnd the internal speaker will have sound by default it comes from dos...When it comes for headphones or speakers u have to install the sound drivers which comes from pc.....install it it will work...
May 20, 2008 | Gateway Computers & Internet
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Apple MacBook Air Logo
674 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
