Question about Midland 1001Z 40-Channels Base CB Radio
CB hook up to car battery for home use
G'Day
I live in rural Queensland Australia, I have an old 18 channel Midland & Electrophone which I would like to hook up to a car battery for home use.
My question is if it is possible to do this using two 12V car batteries & is there a way where you could have one battery charging the other somehow without using an alternator unlike a car & if a fuse is required also & if it possible to talk to friends in the USA depending on the size of the antenna. Having power outages all the time & bad weather I would like to have a backup system for communication if internet & cell phones fail.
Your help would be much appreciated down under here.
Cheers Mate
Stevo
  • 110 Answers
Yes you can do it..
even use wind-mill to make power to charge battery(s)
Serial and parallel battery configurations
http://batteryuniversity.com/partone-24.htm
Posted on Jul 03, 2009
Why won't it change channels, transmit, and make static when turned all the way down?
did you have it on channel lock. I mean look at the knobs and see if you have a 9 - 19 lock ?
Sep 10, 2015 | Midland 75-785 Handheld CB Radio
Midland 75 785 noise problem
change channels maybe it will go away. How is you power hooked up? does it go to the fuse box ,cigarette lighter or directly to the battery? Try hooking the power up differently .If that doesn't work try asking a friend to hook it up in their vehicle to see if it still does it. once you find the problem then install it. Could the nb/anl switch be in the off position ? Good luck.
Feb 07, 2013 | Midland 75-822 40-Channels Handheld CB...
Well i dont really know much about this cobra 20 plus cb lol i know its old. but im trying to see if it is working well i got it hooked up to a battery and the antenna plugged in and it comes on but im not...
check the speaker it may be dry rotted and not working.use an external speaker. depending on the time of day you probably couldn't reach any one any way Get a friend to talk on another radio while you listen and then let him listen for you.
Dec 10, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Can i get it to start on channel 1 and not channel 9
You should be able to. It sounds like your radio is hooked up in a manner that disconnects it from ALL the power once the ignition is turned off. This causes the radio to return to channel 9 by default program when powered on again.
Try connecting the radio hotwire to the fusebox at the factory am/fm radio fuse junction (be sure the amps for the cb + the am/fm don't exceed the rating for the fuse). This should keep power supplied to the radio even with the engine off, and it should remain tuned to channel one every time you turn it on.
Oct 15, 2009 | Midland 77-099 CB Radio
THE WIRES IN MY DAD'S OLD MIDLAND 77-106 MIC. HAVE BROKEN LOOSE
first check out the front for a circle with 27/81 this is the 40 channel (FM). if you cant find the circle it is (AM) and not used as much in the uk. if it means alot to you and your dad post it to cb communications shildon DL4 1HE and i will will see want i can do.
Jul 23, 2009 | Midland 4001 40-Channels Base CB Radio
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Apr 16, 2009 | Midland 1001Z 40-Channels Base CB Radio
Wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Sep 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Cobra and midland cb
It could be that the cb is to small to get your voice out there. I just ran into the same problem with my Midland 77-099 and i got to talking with one of my old family friends, he told me that it was to small and needed to get an amp, so to get an amp and be legal you have to get FCC licensed to run one and then buy you an amp and read the manuals on how to hook it up bc you dont want to destroy the amp or cb itself in a matter of sec. this is all i know to do. Hope it helps if not email me at mag0842@gmail.com
Jul 21, 2008 | Computers & Internet
Midland 1001Z 40-Channels Base CB Radio Logo
588 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
