Question about Westinghouse Dishwashers
No electricity getting to dishwasher
Worked yesterday ok now to-day I have no power showing on the dishwasher checked the meter box ok everything else in house ok the dishwasher is 6 years westinghouse 901 checked switch and all around dish washer looks ok.
Pam.
  • 232 Answers
Check connection at connection box under dishwasher behind lower pannel was ther power to the switch some dishwashers have a thermal fuse in the console white plastic whith two wires going to it
Posted on Jul 02, 2009
No power to my dishwasher. I checked the electrical panel. It's fine.
So the panel is fine - so what! Did you check the power line that feeds the dishwasher? Is it directly wired and not plugged in? Did you use a volt meter? Did you check the wiring for bad connections/ breaks?
Aug 23, 2017 | Dishwashers
Electric dryer will not heat,everything else is working
Unplug power cord & pull the back off and use ohm meter to
to check the heating element also check if the element is ground to the heater box. Check the thermal fuse, the cutout fuse & thermostat on the heater box. Check the operating thermostat and any others you see. Last check the centrifucal switch on the motor the heating wire goes through it. To check this switch connect ohm meter to terminals it will show open unless motor is running so take a screwdriver & lift up on switch button then it should show continuity. Hope this helps
Apr 09, 2014 | Whirlpool LER5636P Electric Dryer
The dishwasher will not turn on. I've already checked my breaker box, and nothing seems to be wrong there with the dishwasher. It worked a few days ago, but now all of a suddden seems to have died.
I would first take a look inside the junction box were the power cord connects to the dishwasher. The junction box is located at the bottom of the dishwasher and can be access by removed the toe plate.
I have seen were one of the wire nuts that connect the power cord will come loose or burn off.
If the power cord is connected ok then I would check the thermo fuse with a ohm meter to see if it's blown.
Aug 03, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
How do i get my dishwasher to work when the power lights and reset buttons don't work?
there is a power issue. 1. check to make sure 110 is going to unit .use a meter at the terminal box.
2. if you have the correct volts thenthe problemis with machine. check on and off switch,door latch,and module. sounds like an electrical problem.let me know if this info was helpful.
Feb 25, 2010 | LG LDF6920ST Stainless Steel 24 in....
My dishwasher wont start
Sounds like you need to check for power to the unit. Access is at bottom of dishwasher under panel. Next you will see the wiring coming into an enclosed electrical box. you will need to get to wires and check voltage on black hot wire to neutral with a voltage meter. If you have power but still doesn't work then at least you know the problem is with the unit and not the incoming power.
Jul 24, 2009 | Dishwashers
Two days ago my LG dishwasher model lDF 7810BB worked fine. Yesterday I loaded it and the display panel will not light nor show any sign of power. I check the circuit breaker several times and all other...
Check for voltage with a multimeter at the wires very near the front, just behind the kick plate. Follow the incoming electrical wire in and remove the little plate the covers the wires/wire nuts. I have seen wires that appear to be connected properly but the circuit is open.
Or, even though the circuit breaker is not switched open, the circuit itself, supplied to the front of the dishwasher is not live/hot.
Good Luck!
Mar 08, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Dishwasher has no power
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpoool dishwasher not turning on model du1050
Make sure you have power to the dishwasher, check circuit breaker. If circuit breaker is ok, then remove toe panel at bottom front of machine, on the right hand side is where the power cable goes into a little metal box. Turn off circuit breaker to kill power to the dishwasher, remove electrical box cover and check to make sure that the wire nuts are tight. Reapply power and test. If still no go then remove tech service sheet from toe panel insulation, get yourself a multi-meter and start test individual components until you find the one that is bad. Hope this helps.
Dec 11, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Oct 16, 2008 | Dishwashers
Half way throu my dishwashers cycle it fuses & turns everything in house off
this happens due to the high electric current requirement of the dishwasher and it is not receiving that required current so it try to start but due to lack of required power it shuts off the current in whole house.
get the electric curren line checked out in your house.
and to check the current in your dishwasher check out this instructions
You will most commonly measure two electrical parameters when you're troubleshooting your appliance: resistance (measured on units called "ohms") and voltage. Typically, both of these measurements are made on a single meter called a multi-meter, which you can set to measure either ohms or voltage.
This shows how to measure resistance. Resistance ( or continuity ) is measured in units called "ohms." You'll commonly want to know the resistance of things like bake elements and solenoid coils. For example, a good bake element typically has a resistance of about 30 ohms. If your oven's not baking and you measure the resistance of the bake element and the meter doesn't move, then you know you have a bad element. A simple ohm measurement can save a lot of money and a possible headache :)
Amp meter: Here's a clamp-on amp meter (or amp meter) being used to measure current flow through a wire. This is a common test for determining whether or not a gas oven igniter is good or bad--only way to really know is by measuring its current draw and comparing to rated draw. You'll also want to measure current/amp draw in cases where you have an electric motor that runs for a few minutes then shuts off on it's built in safety to see if the problem is with the motor drawing excessive current.
Volt meter: This picture shows how to measure voltage. A voltage measurement at the outlet should the first thing you do whenever you have an appliance that is completely inoperative...a simple power test is required if your electric dryer is running with no heat to make sure you have both powers at the dryer
thanks.
Dishwashers Logo
322 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
