Question about RCA F32650 32" TV
My RCA 32" is black and white and color comes in later
TV usually takes a couple of minutes and then again sometimes takes hours to get color but every time color comes in you will hear a popping sound through the speakers other wise it is black and white.
how can this get corrected? is it a relay gone bad
snakehead
  • 1074 Answers
SOURCE: popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good luck.contact me on fixya.com or email me at nicodhem@yahoo.com
Posted on Apr 24, 2007
  • 1694 Answers
SOURCE: RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Posted on Oct 02, 2007
  • 579 Answers
SOURCE: BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Posted on Jan 08, 2008
  • 301 Answers
SOURCE: 52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Posted on Feb 22, 2008
Shuttle83
  • 1139 Answers
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
32" RCA white vertical "Hazing" that eventually clears up
daniel143962
Take you unit to a service center and ask them to fix it. They won't be able too, but ask anyawys. When they tell you they can't fix ask them for the work order and then call 1877-297-8391 and they will help you
Feb 23, 2010 | RCA L32WD22 32 in. LCD HDTV
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at ninalashua@yahoo.com
Jul 09, 2009 | RCA 32F531T 32" TV
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
32F531T color tv loses color after about 15 minutes.
the crt socket of your tvhas a problem,coldsolder the board of your crt socket,if not working replace the crt socket.
Apr 21, 2008 | RCA 32F531T 32" TV
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Aug 08, 2007 | RCA 32F531T 32" TV
Color comes in and out
could be loose connection bad solder or crack,on the main board ,is hard to tell with out open it, you need to have a little experience to do that, 60 to 80 dls depends on the tech who works on it , in shop 125
Jun 10, 2007 | JVC AV-32F475 32" TV
RCA F32650 32" TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
