Question about Ovens
The brackets that hold the glass door in to the handle are snapped where can I get new ones? thanks Carla (NZ suppliers)
  • wairua625 Jul 04, 2009
    Sorry don't have the model but it's a Vulcan brand
    wall oven around 13 years old
  • 232 Answers
Brand and model please
Posted on Jul 02, 2009
  • bill williams
    bill williams Dec 27, 2009
    sorry don't do guess work need model # to be sure get wright part
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
Removing glass from whirlpool oven door
I've removed all the screws that I can see. Looks like the brackets that hold on the handle are keeping the whole thing from coming apart, but the brackets are behind the glass and the screws enter from the inside meaning that I will have to remove the glass to be able to remove the handle.
Resource: http://b2b.lovemyhome.net/
Nov 06, 2012 | Ovens
The glass top on my format oven has a crack in it, can i replace the glass top?
Yes it can be replaced and without to much hassle just a few screws. Finding your glass from your manufacturer would be where i would start first, locating the glass is why most people have to purchase a new stove because parts are not available. Please rate my solution it is how i earn my achievements. Thanks in advance
Apr 13, 2012 | Ovens
WHILE MAKING HOT CHOCOLATE THE OTHER DAY, THE MILK BOILED OVER AND SOME OF THE MILK WENT THREW THE SLITS AT THE TOP OF THE OVEN DOOR BETWEEN THE TWO GLASSES IN THE DOOR. IS THERE ANY WAY TO OPEN UP THE...
First, you will need a heavy blanket to place the door on once you have removed it from the oven. Open the door slightly, until it stays open by itself, about 15 degrees. Lift the oven door off of the hinges and place on the heavy blanket. (The hinges may snap shut when you pull the door up and off, but this is actually normal. It takes a bit of finesse to get the door back on the hinges if they will not stay out.)
Remove the 4 screws across the bottom of the door. Next, stand the door up with the bottom on the blanket and the front facing you.(Hold the door by gripping firmly around the middle edges to maneuver door)
Now, while holding the handle, remove the 2 screws that hold the handle on, unscrewing them just enough until the handle is free. (You do not want the spacers dropping off the screws) Hold the door together with one hand while placing the handle out of your way.
Once again, grab the door firmly by the middle outer edges and lie the door down, the inside facing down. You should be able to lift up the outer panel and glass and clean the inside of the outer glass.
Reverse the above procedure to reassembly the door. You can also take the door apart further if you have stains inside the other glasses. Here is a link to a schematic for your oven door.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0211500-00004.png
Apr 15, 2011 | Kenmore Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
Apr 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Jan 25, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
