Question about Emerson DTE315 TV
Screeching noise form my tv
Screeching noise fform my tv
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
On my 1995 toyota Camry the disc brakes are screeching when I hit them.
hi any kind of screeching noise normally means uve got a metal on metal contact so i wd say u probally need ur pads changing also the rust that forms is totally normal when not used for a while goodluck
Mar 26, 2012 | 1995 Toyota Camry
Wont accept a new toner cartridge makes a very
you have to cleaan all the gears. on the side and use a bit of oil.
this is a commen problem form sf 5100
May 17, 2011 | Samsung SF-5100 Plain Paper Laser Fax
I have my computer monitior hooked up to my polaroid flat screen tv. Worked fine for a while, then got a blue screen that says "not support". It has also been making a loud screech and a crackaling noise....
The 'NOT SUPPORT' message is due to the video signal resolution form your PC is too high for the TV to display, you need to set your PC video resolution to the native resolution of this TV.
Loud screeching sound may be causing by failing amplifiers if it comes through the speaker or may be from the power supply module due to bad/dying DC filter caps.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 01, 2010 | Polaroid Televison & Video
Sound goes off to a screeching noise
There is no "sound board" on Samsung machines. The audio circuit is a part of the Main board. Depending on who you get it from, the cost of the board is usually $325.00-$350.00 plus 1 hour labor.
Jun 16, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
I got a sig 552 airsoft gun but it dosent fire it screeches
i have a sig 552 as well and had similar problems but if you take it apart the trigger box will come out and you just need to mess with that a little bit
Apr 01, 2010 | Ics Hop Up Bucking for Airsoft Guns
Jul 02, 2009 | Emerson BAR322 13" TV
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
White noise on screen with screeching sound
white unstable lines plus screeching noise it basically due to loose contact at input 1 like antena or cable wire or socket loose. 2 loose contact some where in your tv. 3 loose contact in some electrical thing. 4 loose near tuner section. hope this will help.
Oct 01, 2007 | Toshiba CF32F50 TV
Emerson DTE315 TV Logo
277 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
