Question about Samsung Rant Cell Phone
My phone is stuck on the "samsung" screen
So my phone had frozen while using my internet feature so i removed the battery and when i put it back in and turned it on the "samsung" screen shows and repeatedly flashes. it doesnt go past this. any suggestions?
  • 389 Answers
It needs reflash.
Posted on Jul 02, 2009
Touch screen on phone quit working
Dianna,
You'll first want to make sure that the phone isn't just frozen. If you have a removable battery, take it out, wait 5 seconds, and put it back in. If the phone was frozen, this will reset it, and you should be able to use your phone like normal. If it doesn't have a removable battery, let me know what kind of phone you have, and I'll tell you how to reset it.
If that doesn't work, you'll unfortunately have to take the phone in to your carrier, as they'll probably need to replace the phone.
Dec 22, 2013 | Samsung Cell Phones
Frozen mobile touch screen
sounds like you bricked it. try taking the battery back out than hold the power button for 5-10 seconds than put the battery back in and try it than.
Dec 10, 2013 | Samsung Cell Phones
Frozen A-887 too many attemps frozen
Try removing the battery out of the phone, and putting it back in again. It should be unfrozen when you start it up again. (Battery usually located at the back of the phone)
Aug 30, 2012 | Samsung Cell Phones
My metro pcs htc wildfire s is frozen on the unlock screen
try hard resetMaster reset using hardware buttons: HTC Wildfire SVERSION 4 Created on: 15-Aug-2011 09:21 by tmo_brian - Last Modified: 07-Mar-2012 16:29 by tmo_josh_m
To perform a hard reset using the hardware keys, follow these steps:
  • Note: A hard reset restores the original factory settings and erases content, including downloaded ringtones, images, programs, and contacts stored in the internal memory. This feature allows for resetting of sound profiles, display settings, and phone or memory card settings. However, if you want to try resetting some factory settings without losing any data, then clear system cache before a master reset.
  1. Back up all necessary data and synchronize files. See: Prepare for a master reset and back up data on Android
  2. If the phone is plugged into the charger or USB cable, unplug it.
  3. Remove the battery.
    • Important: Removing the battery is required. Turning off the phone with the Power key does not work, because of the Fast Boot feature.
  4. Re-insert the battery.
  5. Press and hold both the Volume Down key and the Power key. Do not release the volume key, continue on to step 6.
  6. Release the Volume Down key when the three Android images appear on the bottom of the screen. The following options display:
    • FASTBOOT
    • RECOVERY
    • CLEAR STORAGE
    • SIMLOCK
      • Note: If you are stuck on a screen that says 'HBOOT' and 'FASTBOOT' without any other options to choose from, it means you have pressed the Back button. To get to the regular options, press either the Power key on HBOOT or the Back button.
  7. Press the Volume Down key twice to select CLEAR STORAGE.
  8. Press the Power key to initiate the master reset.
  9. Press the Volume Up key to confirm Delete all user data.
  10. Wait as the device clears the user data then restarts.
DOC-25626
Aug 30, 2012 | HTC Wildfire S White Metro Pcs Android...
My touch screen is frozen and I cannot access my menu, contacts or anything. How do I do a hard reset?
remove the battery for about a minute. put the battery back in and start up the phone.
please take a moment to rate this solution
thanks
robert
Nov 03, 2010 | Samsung SGH-A877 Impression Cell Phone
Completley frozen am unable to access any features
hi, try switch it off..if this is not possible, try remove the battery and put it back to restart the phone..my advice is that you could delete some things on the phone, make sure you have enough space on the phone, try not to overload the phone or memory card memory of the phone..also delete any application that is not compactible with the phone.
Jul 15, 2010 | Samsung SGH-G600 Cellular Phone
Frozen on a application screen
It is not the battery that is the problem it is the v-chip under the battery.
Remove and reinsert with phone off.
Turn back on and phone should be reset.
My wifes phone freezes like this from time to time and this is what works on her blackberry.
Sep 18, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Frozen on Samsung Screen
You should remove the battery for 2 minutes and then put the battery back in and restart the phone.
Good Luck!
Jul 02, 2009 | Samsung Blackjack SGH-I607 Smartphone
Samsung T629 stuck at splash screen
Take your sim car out and try using these codes to reset the phone.
*2767*2878# and *2767*3855#
Your phone software could also be corrupt.
If you go to samsung you may be able to update the firmware in the phone over the internet.
If all else fails have the phone re-flashed by a technician.
Mar 02, 2009 | Samsung SGH-t629 Cellular Phone
Phone frozen
Is there a memory card in the phone? If so, it might be causing a problem. I just had the same thing - phone was stuck on the opening screen. I took it back to the shop. By a long process of elimination involving other handsets and sim cards, we eventually realised it was the memory card, which i have now thrown away.
So if you have a memory card, take it out. If there is still a problem, remove the battery and sim card, put them back in, turn phone back on (without memory card).
Hope this helps,
Aitch
Dec 30, 2008 | Samsung J700 Cellular Phone
Samsung Rant  Cell Phone Logo
460 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
