Car will not move when it is in gear and gas pedal is pressed. The engine will rev up but car will not move
SOURCE: engine revs but car doesn't accelerate
Since you did not say what type of transmission you have i will suspect the clutch is slipping if it's a manual.
If it's an automatic, it could be several things. Low fluid level...clogged filter, fluid needs to be changed..transmission serviced...weak pump, bands/clutch packs worn...etc
Good luck..i hope this helps, please rate me a fixya.
