Question about Maytag Neptune MAH5500B Front Load Washer
Washer won't spin.
I have a 2005 maytag Neptune, and the clothes aren't spinning dry like they normally do. After doing a little bit of research online, I discovered that they have a suds sensor on them and if too much soap is used, it will shut down the spin cycle. My mother in law has been doing her laundry here while I'm at work so I don't know how much soap she has been using...hopefully that's all it is, probab#ly not though.
When I do a load, and put the next in, I push start, and it beeps 3 times and won't turn on. I find that if I wait about 45 minutes to an hour, it works fine. Till it stopped spinning that is. It has been acting up for about a week and I have stopped using it till I figure out what is wrong. I'm thinking a burnt board...this is getting expensive. :(
    Problem Solver:
  • 9 Answers
Fortunately boards for most washers are cheap. Rebuilt board= $35 to 100: look online.
But your washer probably doesn't have a bad board. It sounds more like a motor. Does the mother-in-law like to overload the washer so she can get out of your house faster? If your motor overheats there is a bimetal switch that must cool off before it will run again -kinda sounds like your problem.
HonestDan
Check my eBay auctions -ID= Jerrycia95*
Posted on Jul 02, 2009
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Front Load Washer is not draining all the way most likely not spinning well either. Clothes still have water in them when removed from washer and take forever to dry. Has anyone experienced...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 04, 2011 | Maytag Neptune Washer
My maytag neptune washing machine is not spinning out the water from my clothes once its done washing. My clothes are still soaked even after its done and theres a little bit of water left in the...
you have a partially blocked drain from the tub down thru the pump to the drain pipe,remove the lower front cover and remove the drain cleanout and check for blockages in these hoses
May 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Not spinning to spin-dry clothes.
first check the motor bushes they are more than likely to of worn.
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
What will the Max Extract button do?
The max extract button will do an extra spin to get any & excess water out of the clothes. It is a good thing to keep on to help cut down on drying time. If you find standing water in the washer, it is possible the hose is NOT in the correct position.
May 03, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
490 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
