Question about Maytag Dishwashers
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
  • 630 Answers
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Posted on Jul 02, 2009
How do I get the top sprayer arm to spin? I have cleaned and checked for clogs.
Hi
As you have already cleaned and checked the arm for any clogs then please make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low. The top arm spins freely. If not then check the bearings for the arm. Hope this helps...please post back for further assistance.
Daniel
May 09, 2011 | Whirlpool Gold 24 in BuiltIn Dishwasher w...
We have a built in GE dishwasher. It has worked fine for about 4 years but now the glasses in the top rack will not come clean. I have cleaned all the holes where the water comes out but I think the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 13, 2010 | Maytag Dishwasher
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
What would stop the sprayers from spinning freely, A bearing?
Plugged, take em apart and clean all the crud out of them, its alot of work but has to be done.
Apr 22, 2010 | Hobart AM14C-155 Dishwasher
Sprayer arm wont spin and soap sits in bottom
Hi-- Could be, but let's go over this stuff first. Remove the sump cover and spin the pump blade on the end of the motor.  If it is difficult to turn or 'rough' feeling, then motor is probably bad.  One time I found a bottle cap that a little Dennis the Menace had put in the dishwasher.  It made a perfect plug for the sump intake!  Anyway, if you can pull and re-install a dishwasher then replacing one of these pumps is easy. Part is about 140$.  Let me know if this info helps.  Please acknowledge this post. Thanks-Ed
Mar 27, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Soap stuck in dispenser/dishes not getting clean
try and find a manual to assist you, pdfoo.com , but most ot the sprayers have clips that hold them on/in. just be carefull not to break any.
Jan 21, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
TUW model - not cleaning fully, top sprayer does not spin
make sure the wash arm holes arent obstructed and the wash arm seams arent cracked.
Sep 17, 2007 | Champion 24 in. UH-150B Built-in...
Dishwasher appear to be clogged
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 07, 2007 | Maytag MDB7100AWB Dishwasher
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
465 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
