Question about Flotec FP0S3200A-01 1/2 HP 3,200 GPH Plastic Sump Pump
Flotec 3200a sump pump sensor not working - Flotec FP0S3200A-01 1/2 HP 3,200 GPH Plastic Sump Pump
  • mike_b_jones Jul 03, 2009
    Thank you, do you know how to adjust the sensor so that it is more sensitive. I want it to keep my sump dry. I hate having stagnant water in my basement. I have a feeling you may just say get a new pump. Anyway any advice would be helpful.
  • mike_b_jones Jul 12, 2009
    Thank you for your advice. I got it working but it did not drain until low for a week or two. Then suddenly its always lower then usual. I hope its draining and not leaking. I will wait until a rain. Thanks for you help in Cape Cod.
    President:
  • 1,723 Answers
Check the connections in the float switch (sensor). Give it a bang it may be stuck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
  • Craig Butler
    Craig Butler Jul 05, 2009
    You may be able to put the pump lower in the sump, I don't know of a way to adjust it though. It makes contact as it falls to a certain angle, give it a look, maybe you'll see something.
Where is this adjustment on the flotec laundry pump
Owner's Manuals - Flotec Pump
www.flotecpump.com > Flotec Resources
Are you having a hard time locating a hard copy of your owner's manual? No sweat. We've got it right here. 4" Submersible Pumps. FP3222 ' FP3232 ' FP3212 ...
Jul 26, 2014 | Flotec Fpos1800a 1/4hp Sump Pump
My flotec E100ELT Intellishield pump control will not start unless I unplug power cord from pump control then replug to activate pump and high water alarm does not sound.
pump works fine..when plug in directly..sensor unit does not work all the time and is flooding the basement..how can i resolve this...where can i get just the sensor replaced
Jan 31, 2013 | Flotec 1 HP Electronic Sump Pump E100ELT
My Flotec Model FPSC3200H-01 1/2hp sump pump stopped working.The motor hums but impeller will not turn.
Well I know it a dirty job but someone has to did. Unhook the pump from the plumbing and take the pump out so you can see what fell into the sump pit and is lodged in the impellers.
If you have it out already turn the impiller backwords and see if that frees it up.
Feb 05, 2011 | Flotec Plumbing
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
http://www.flotecpump.com/
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump quite working
Start by checking float switch
Jan 09, 2010 | Flotec 1/4 Horsepower Sink Pump System
Flotec FP0S3200A-01 1/2 HP 3,200 GPH Plastic Sump Pump Logo
607 people viewed this question
Top Flotec Electrical Supplies Experts
Craig Butler
Craig Butler
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
