Question about Motorola Mobility H700 Wireless Headset
I ve got a H375 headset, i try powering it on by pressing the on button right. When i do that, the purple light just stays lit! it doesnt turn blue. So it doesnt switch on at all!
How do you turn the samsung hm3700 bluetooth on? How do you snyc it to your phone?
To turn on the Samsung HM3700 headset, slide the power switch up. (You can see it's location on the image below). The indicator light below the power switch will blink blue 4 times (purple or red means your battery is low). If it stays blue it is ready to sync with your phone.2_29_2012_5_42_10_pm.jpgThere are 3 ways to sync this device to your phone:
  1. Once the headset is on, hold down the talk button for 3 seconds. (the blue light will stay lit for 3 minutes once you enter pairing/syncing mode).
  • Activate Bluetooth on your phone and search for the hm3700 (keep them close to each other).
  • Select the headset and enter a PIN number if asked.
2.) Active Pairing: Once you have held down the talk button for 3 seconds and the blue light is on, press and hold the talk button again to make the blue light purple.
  • The device will try to automatically connect to your phone for 20 seconds. Your phone should not be connected to other Bluetooth devices during this process.
3.) FreeSync is an application you can download if you have an Android (from the Android Marketplace). It allows you to access your headset settings and I believe it can read your text messages for you (text to speech).
For more information the user manual for your Samsung HM3700 Bluetooth headset can be found here: http://downloadcenter.samsung.com/content/UM/201111/20111116163119314/HM3700_UM_America_B_Rev.1.0_110923_screen.pdf
Feb 29, 2012 | Samsung Cell Phones
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
H700 Motorola Bluetooth Headset
Make sure that any devices previously paired
with the headset are turned off. If the indicator
light is flashing in blue, turn off the other device,
then close and reopen the headset boom. The
indicator light becomes steadily lit in purple
indicating the headset is now in pairing mode.
Jan 03, 2010 | Motorola Mobility H700 Wireless Headset
H700 bluetooth help
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
The purple light will not stay lit as long as the mic boom is closed.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 05, 2009 | Motorola Mobility H700 Wireless Headset
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
Trouble getting motorola headset to pair with my samsung phone
Here is what will work.
Fold the microphone in the closed position on the headset.
Now hold the button down and open the microphone out while still holding the button down. Assuming that you phone is in the Bluetooth mode searching for a device, you should see your headset listed.
Jun 04, 2008 | Motorola Mobility H700 Wireless Headset
Can't connect my headset
Hold the button and as soon as the light turns purple, open the boom and in a second it should stay lit purple, now you can pair the two.
Hope this helps
Mar 29, 2008 | Motorola Mobility H700 DOLCE & GABBANA...
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
Help hooking up my bluetooth ear piece
ok it took me a while the way u need to do this pairing is easy they just explain it really bad.
in your phone find the add device
press the call button till the purple light comes on
open the FLIP(microphone part AND THE EAR PEICE!!! people for get the ear peice)
press ok and have your phone start searching
once it finds the device press 0000 for the pin
your all set i almost sure this will work!!!
Feb 12, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
198 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
