Question about Kenmore Sewing Machines
Sears Kenmore Sewing Machine, model 158.504
I have a Sears Kenmore Sewing Machine, model 158.504. Where can you find the manual for this machine? I've searched the Kenmore site, but no luck.
SOURCE: thread a kenmore 158 13410????
Not sure if I am too late, but it's pretty basic. I have the same machine...
You have the thread on the spool with the thread on the left side (unrolling off the spool counterclockwise) and put it around the round thing on the front middle (looks like a snap sort of) and through the eye almost right in front of it (the loop) and hold the thread lightly then wrap the thread around the tensioner (the thing with the dial) to the left (counterclockwise) until the springs "pops" it into place. Then run the thread through the little hook thing (by entering from the left) then up to the eye (hole) that is in the little arms that raises and lowers (you might need to spin the wheel to get the arm in the right position) then you run the thread back through the hook thing (entering from the left) around the little half circle thing (by entering from the left) and finally in the hole in the needle...
hope it made sense, I tried to use laymen terms...
good luck!
Posted on Jul 09, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: users manual for OLD kenmore sewing machine(158
I need the instruction manual for a Kenmore sewing machine 158.19141
Posted on Jul 12, 2009
  • 255 Answers
SOURCE: how to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Posted on Jul 30, 2010
Manual for kenmore sewing machine model 158.18032
Type manual for Kenmore sewing machine model 158.18032 in your search engine on your computer, it will take you to where you need to go.
Jul 11, 2017 | Kenmore Sewing Machines
Looking for a manual for sears kenmore portable sewing machine model 158.13200
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Kenmore Sewing Machines
Do you know where I could find a downloadable users manual for a Sears Kenmore model 15813201 sewing machine.
check with these 2 sites below & email them or call them
sewvacdoctor.com
a1sewingmachines.com
Oct 06, 2012 | Sewing Machines
I need a free manual for at 54 stitch sewing machine Kenmore 385 16554
Make + Model + the word "Manual"
or contact manufacturer support.
Aug 27, 2011 | Sewing Machines
I need the manual for my Kenmore 385.12908
I was, also, looking for this manual. When I searched on Sears for the 908 model it is inferred as being within the model range of 12912-12916.
Using that information, I searched for:
"kenmore sewing machine manuals 385.12916"
on Google and the first result is the below link where there's an "open as pdf" button, I downloaded the manual, it's a very good digital copy.
Here's the better (and free) solution:
http://homeappliance.manualsonline.com/manuals/mfg/sears/38512916.html
Feb 27, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Owners manual
Sears Parts Direct (800)366-7278 or an online site tha has them. Sears/KMart should have provided that for you!
Aug 29, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
681 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
