Question about Intel PRO/Wireless 2011B LAN Enterprise Access Point (WEAP2011BRW) 802.11b
How do i change the password on a intel pro wireless lan 20011b access point
  • 33 Answers
You may visit some ip address details sites.....
Posted on Oct 21, 2010
  • 57 Answers
  1. Select Configuration|Security from the Access Point menu tree.
  2. Select Modify|System Password.
  3. Configure the AP password settings as required:
    System Password Select any alphanumeric, case-sensitive entry of up to 13 characters. The characters selected are displayed as asterisks. Changing this passowrd changes the Read/Write Community password found in the SNMP Configuration screen. The default password is Intel. Confirm System Password Select the same alphanumeric, case-sensitive entry of up to 13 characters as System Password. The characters selected are displayed as asterisks.
  4. Select Save Settings at the bottom of the page.
Posted on Jul 02, 2009
    Problem Solver:
  • 15 Answers
First Check the server IP-Address Details Using the site http://www.ip-details.com/
I have an intel pro/wireless 5000 pci mini card and it wont detect any wireless networks
The Intel WPCI5000 adapter operates at IEEE 802.11a-(1999 standards on a frequency in the 5GHZ range). Modern routers, for IEEE 802.11b/g, operate at 2.4GHZ and cannot talk to your wireless adapter. You need to have a compatible adapter in your computer such as a Tenda-150Mbps-Wireless-Adapter-W311MI available from Amazon for about $9.
May 21, 2014 | Intel PRO/Wireless 5000 LAN Access Point...
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Can I set the WNR1000 as an access point
Yes, You can set it as a wireless access point. All you need to do is follow the steps below.
1. open internet browser, enter on the address bar http://routerlogin.com
2. username is admin, password is password.
3. Go to wireless, change the wireless settings like the ssid and setup the encrption. Go to LAn settings under advance.
4. Disable the dhcp server and change the ip address of your WNR1000
ex. You plan to connect your wnr1000 to a w ired route rwith an ip address of 192.168.1.1. You can set the wnr1000 to 192.168.1.x ( except 1)
Save the changes,
Plug the access point wnr1000 to the lan port on the main router and the other end also on the lan port on the wnr1000.(LAN to LAN)
It should be working now as an access point.
Kevin
Jul 03, 2010 | NetGear WNR1000 Router
NOT ABLE TO LOGIN WIITH DEFAULT USER AND PASSWORD
If there is a reset button then reset it and then try with default user name and password.
Jun 05, 2010 | Intel PRO/Wireless 5000 LAN Access Point...
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Changing the password
  2. Select Modify System Password.
Jul 02, 2009 | Intel PRO/Wireless 2011B LAN Enterprise...
I have forgotten my password for my wireless internet connection.
Connect to Wireless router using LAN cable.
Open Router admin page using the gateway address you get from your network status window from Systray (Support tab in XP).
Follow router instruction to set new WLAN protocol and Password (WPA-PSK for better protection) and use new passphrase (or Key) to set PC client network card protocol.
If Router is Password protected and you missed it: reset to factory settings to reconfigure.
Dec 27, 2008 | Intel PRO/Wireless 2011B LAN Enterprise...
Wireless device problem
For virtually any router, wireless access point, or modem, you will find a tiny round hole just big enough for an unbent paper clip to be inserted. The word reset may be next to that hole, but not always.
Pushing the unbent paperclip into that hole firmly for 10 to 30 seconds will reset the device to the original factory settings.
If you have the quick-start guide or manual for the device, you can use that to set it up. If not, visit the web page for the company and look for tech-support or downloads to find the manual for that particular device. You can also Google the actual device and part number information along with the words 'manual' or 'setup' and find the page that way.
Sep 05, 2017 | Intel PRO/Wireless 2011B LAN Enterprise...
Intel PRO/Wireless 2011 LAN Access Point (WEAP2011EU)
Usually there is a paper clip sized hole in the back of the WAP that you insert a pin or paper clip into for 10 seconds.
Jun 09, 2007 | Intel PRO/Wireless 2011 LAN Access Point
Intel PRO/Wireless 2011B LAN Enterprise Access Point (WEAP2011BRW) 802.11b Logo
234 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
