Question about Nokia 3110 Cellular Phone
Nokia 3110 classic Have the problem of restrart automatically?
Mostly when I insert a external memory card then it is automatic restart.
  • 112 Answers
Its not a problem when insert a new memory card you need to restart the phone for it work fine. or this is what you should do, whenever you want to change memory card on your phone turn it off and insert the card the turn the phone on again. its a simplication. i think this solution will help you if apply it. thanks
Posted on Jul 02, 2009
My nokia model 3110 is automatically gets switched off while inserting memory card
the memory card is not supported by that fone ie maybe the capacity is beyond the maximum your fone supports... or a corruput memory card.
Apr 07, 2011 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Switch on, automatically switch off
repairmobiles.saaqi.com/3110c-lcd-display-back-light-problem/
Jun 08, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 reset codes(reinstall software code)
nokia 3110 reset codes ,i m using 2 gb memory card.when i insert the memory card it automatically swicth off and on after that. after emoving card it gets normal.mamory card is ok.itz new one card..
reply soon
Apr 27, 2009 | Nokia Cell Phones
Phone restart automatically
enge cp poh pde khit anung unit
Apr 18, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Restart my nokia 3110c automatically
hi,restart my nokia 3110c automaticly 3 times and then swich off.what is the rision send me solution.
Sep 10, 2008 | Nokia 3110 Cellular Phone
NOKIA 3110 CLASSIC RESTART PROBLEM
salam
restore ur mobile factory settings
apply only builtin themes of nokia
do not fill ur mobile memory and always leave space of 500 kb
delete ur notes and celender notes
do not apply heavy wallpapers
hope the answer of question
Sep 09, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
97 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
