Question about Panasonic PT L720E Multimedia Projector
Panasonic PT l720e - Standby Mode
HI, sorry to bother you and I dont usually do this. I am only doing this as you are the only people i can find that have the manual.
My Problem:
My projector is stuck in standby mode. It doesn't even turn on just goes straight to standby. I dont have a remote and understand that this model is discontinued. Is there a way to get it to turn on without paying $.
  • Anonymous Jun 01, 2008
    I change the lamp
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
  • 563 Answers
SOURCE: Panasonic PT L501U Projector
Hi there
Have you replaced the lamp ?
If you haven't - take out the lamp and chech for any irregularity on it - i.e. - discolouration , vein like looking marks ( black or white ) and also if the shape of the shaft is off.
If there is no visible damage it might be a faulty Ballast ( lamp's powersupply ) - especially if you cannot get it out of stanby once it has shut down.
Posted on Apr 17, 2008
  • 3 Answers
SOURCE: Panasonic VieraWidescreen Plasma TV Model No TH42PA50A - Power standby mode and tripping off automatically, Please help
Here are a couple links that give definition to the problems. Hope it helps.
Posted on Sep 13, 2008
  • 3 Answers
SOURCE: Panasonic PT-AX100U-EC
I just repaired mine with some oil for the iris assembly.
The problem is the iris is either slow to respond or doesn't respond to it's controller. The cam should snap back to it's resting point and move freely. It needs to be re-oiled. Mine would move but sluggishly like it was sticky. There are TWO pivot shafts to oil. One on top and one on the bottom. The bottom one can be accessed by removing the bulb. You can see the bottom cam while the bulb is installed. This is a good point to test the iris movement at.
You need to have some mechanical ability. If you don't think you can do this then don't.
First remove the bottom bulb cover. Now get a flashlight. Look in the area that bulb is pointing towards. In the left corner of the side towards the front of the unit where the lens is, you will see a brownish cam. It has a spring around it.
Take a small screwdriver and move it to it's extent like a wheel. Let go and it should quickly return to where it was. It virtually snaps back to it's resting point. Do this several times. 5-6 If at any time it returns sluggishly then it needs to be oiled. 3 in 1 oil works great.
This takes time. I used a small jewelers screw driver to deliver the oil. As you oil it move the cam back and forth to work the oil to the shaft. Standing the unit on edge after you put the oil in the gap helps the oil get to the shaft.
If it now starts to snap back put the bulb cover back on and try the unit. If after 5-6 movements it still does not snap back each time then the actual motor shaft needs to be oiled as well.
Take the top off. There are several screws and one on the back. All have an arrow marking them. The cover is caught around the lens assembly. You have to be a little bit violent to get it off. After the cover is removed, you have to really look for the upper iris cam. It is under the large multi pin connector with brown wires on the main main display board. There is a small perforated metal cover under this connector.
After bending the cover up you will see the linear motor that drives the iris. There is a small flex cable going to it. You need to oil it's shaft. Use the same procedure to oil it as the cam under the unit. After oiling this shaft the iris should now snap back to rest every time. That's it.
Posted on Jan 04, 2009
  • 133 Answers
SOURCE: Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Posted on Jan 08, 2009
Changed my projector lamp yesterday, it work for about 4hours and went on standby. its now on a stanby mode and all effort to switch it on has not been successful. Please help me
Is your projector connected to a source? ( Computer, DVD, or any device) make sure the connection is tight/properly plug in so that the projector will recognize the device attach to it and override the standby mode.
Hope this helps, thanks for contacting Fixya. Please keep us posted of issue. Cheers!
Dec 09, 2010 | Panasonic PT-AX200 LCD Projector
Projector will not switch between eco and normal modes
Hi imustafa
Sounds like the lamp may be on its way out... at least is low on output.
May 05, 2008 | Panasonic PT-AE700U Multimedia Projector
Does not turn on the power green ligh keep flashing no picture and no sound
If after the fault the TV went in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage
In that case follow the troubleshooting here Why my TV does not start up and remains in standby.
The best way to contact an authorized technician is by ringing the phone number listed on the owners manual.
Try first the troubleshooting proposed in link above. If that does not work, ring Panasonic customer service.
May 11, 2010 | Panasonic PT-61DLX75 61" HDTV
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Panasonic tv
sorry, not for that model i dont. Sorry I would try the local repair shops they may have one used
Aug 20, 2008 | Televison & Video
Please send me the instruction on lamp replacement
sorry I dont have the instructions for panasonic. but it should be straight forward remove the back and the lamp housing should be right there.
Mar 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Driver for the Panasonic PT-LB60NTU
To my knowledge, the Panasonic PT-LB60NTU's wireless connection to a MAC is not supported, sorry.
Kind regards.
Feb 07, 2008 | Panasonic PT-LB60NTU Multimedia Projector
Panasonic PT L720E Multimedia Projector Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
