Question about Intel D845GVSR Motherboard
USB not woking
After installation of bios updatation of D845GVSR i am unable to access USB.power is ok for the devices which i connected to USB cable
  • 144 Answers
As simple as it sounds , make sure the option in the bios relating to usb is not set on disable. Sometimes when you update the bios it restores all default bios settings automatically. The default for usb might be disabled , just check and make sure USB is switched on.
If you found this solution helpful , please rate below
Kind Regards
1234s282
Posted on Jul 03, 2009
Usb types connections
try another k/b or update usb driver. if not try to reinstall windows.
Oct 23, 2013 | Dell OptiPlex GX520n PC Desktop
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
ML 2240 printer not detected by Windows 7
Try installing it in safe mode.
To go to safe mode, do the following:
Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions.
If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers.
After fixing all driver related issues, try installing the printer again.
I hope this helps!
David
Feb 25, 2013 | Samsung ML-2240 Laser Printer
Failed BIOS update
CMOS battery.
hope this helps
Sep 11, 2012 | ASUS (P5RC-LA) Motherboard
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
How do I get access to broadband. I have all the modems, ethernet cable links that work on another machine, but when I plug the ethernet cable in to my Emachine with a D845GVSR motherboard, I get no link...
if you need an ethernet driver or it might be something else
If you are trying to connect through a modem/router the ethernet driver should have come with a motherboard disc or the one supplied by your ISP internet service supplier
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps
Apr 07, 2011 | Intel D845GVSR Motherboard
I have an Intel D845GVSR motherboard. The 4 back USB ports are enabled but the two front ports aren't. I also have a Creative Combo NS DVD ROM with card readers in it. My Computer guy enabled the card...
This is probably set in the BIOS. You need to reboot the computer and enter the Setup/BIOS to enable the ports. Otherwise they're physically disconnected in the case and you will need and expert to reconnect.
Mar 07, 2011 | Intel D845GVSR Motherboard
I just bought an ASUS notebook but the USB cannot read any device what do i do?
Hi,Some USB devices are not APM/ACPI friendly and may not operate properly after resuming from Standby or Hibernation. Some of these steps may not apply to your computer. Test the attached USB device after performing each step.
1. Verify that a USB port and an operating system with USB support are being used to attach a USB interface external device to a ThinkPad system.
Note: The following is an example image of a ThinkPad system USB port
USB port
2. Verify that the latest BIOS and embedded controller for the ThinkPad system has been installed.
View the latest BIOS files for all ThinkPad systems(-307.ibm.com/pc/support/site.wss/BMOE-3VAM8Y.html)
3. Verify that USB is enabled in BIOS.
* For ThinkPad A, G, R, T, X and Z series systems
1. Turn on the computer.
2. While the "Press F1 for BIOS Setup Utility" or "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower left area of the screen, press the F1 key, blue Access IBM, or ThinkVantage button.
3. Select Config and then click USB. The window should list USB BIOS support as [Enabled].
For ThinkPad 600, 600E, 770, 770E/ED, 770X, and 770Z systems
1. Press and hold the F1 key and then turn on the computer. Hold the F1 key until the Easy-Setup menu appears. If a password prompt appears, type the correct password.
2. Select Config.
3. Select Initialize and then click OK.
4. Click Exit, click Restart, and then click OK to restart the system
4. Verify that the USB device and any required drivers were installed in accordance with the manufacturer's instructions.
This may require removing the USB device and the drivers, and then reinstalling the USB device and the latest drivers.
5. Verify the USB device works on another machine, if available.
6. Verify another USB device, if available, works on this machine.
7. Verify that the USB device is USB 1.1 or 2.0 compliant.
Plugging specific USB 1.1 compliant devices into a USB 2.0 compliant port will cause an error message dialog box to appear. That dialog box details that a non-high speed device has been attached to a high speed port. The device should function normally, but at a slower speed than if a 2.0 device is attached to 2.0 port. Most USB 1.1 devices will function normally in USB 2.0 ports.
8. Verify that external power is attached if required.
Some USB 2.0 devices will require additional power from external sources or an additional USB port to function correctly in USB 1.1 compliant computers.
9. Verify that the latest Microsoft Windows Service Pack has been installed for the operating system installed on the computer.
There are updates and fixes to USB 1.1 and USB 2.0 available in Service Packs.
10. If an operating system was installed from a retail CD, then refer to installing USB 2.0 support on ThinkPad systems.
11. Test the USB port for errors.
Run the PC Doctor diagnostics for all current ThinkPad systems. PC Doctor for DOS is available by pressing the F11 key or the blue Access button during startup to access the predesktop menu area. If these methods are not available for your system, then PC Doctor for DOS may be downloaded. This DOS version requires two or more floppy diskettes depending on the ThinkPad system.
12. If these steps have not solved your problem:
Refer to "Need more help?"
You could also try downloading an updated/fresh copy of the drivers for my specific model notebook from Asus's web site and just reinstall over the old ones.
And if you don't understand much about it, i would advice you take it back from where you bought it from and get a replacement if it's on guarantee...
Thanks for using fixya....
Nov 01, 2010 | Computers & Internet
USB hub problem.i have a 4-way USB powered hub that has taken it upon itself not to rustle up every now and again on boot-up. Power LED is on but the four green LED's are out and everything connected to it...
Perhaps the problem is not with the powered USB hub but rather the USB port it is plugged into, or the cable connecting them.
Plug the USB hub in using a different USB port on your system or connecting it using a different cable to see if that makes any difference.
Aug 15, 2010 | Mini Computers & Internet
Intel D845GVSR Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
