Question about Cameras
Olympus lens om zuiko MC auto -s1:1,8
How to open front lens? The shater ring  not responding?
Regards Ellis
    Champion:
    Scholar:
  • 216 Answers
Atdlee@netzero.com
Posted on Jan 18, 2008
Why wont my Olympus zuiko 300mm lens zoom to max length?
Most camera's can't focus when the aperture number is above 5,6. Although your tele zoom starts at 4,8, it reaches the 5,6 at about 150 mm. So from there and up it can't auto focus. You still should be able to focus manually, but for wild life or sports pictures, it is useless.
Aug 25, 2014 | Olympus M 75-300mm F/4.8-6.7 ED Zuiko...
Joao Tavares
Usually those lenses have retaining rings that unscrew from the barrel of the lens. My guess (not having seen the exact lens) is it's the same with your lens.
I would suggest you get a set of micro straight edge screwdrivers and a rubber cap and lid remover, like those sheets of rubber you use to get a better grip. A rubber glove may do the job if you don't have one, but make sure to wash any powder off the glove before you start work.
Start by taking off the first retainer, which is that thing with the printed letters and numbers on it. If you can't get enough friction with the rubber on it, then use the micro screwdriver. The way to use the screwdriver is to stick the tip onto any sort of dimple on the retainer, such as the lettering. It will damage the printing, but on a cheap lens it won't matter much. There may be other retainers you encounter as well that have a notch in one side that you can slip the screwdriver into and use that to turn the ring.
Nov 27, 2013 | Olympus Normal Zuiko 50mm f/1.8 Manual...
Have olympus om g.zuiko auto-s1:1.4 f=50mm with bug within the lense. Attempting to disassemble. Need diagram on disassembling parts step by step. Need help.
I went on the net to try and find a manual, to no avail. My suggestion would be for you to contact Olympus support, and see if they can supply one. Here is their site:
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
If you scroll down the page a bit, you will find a section to contact Olympus. Hopefully, they can supply one, otherwise you will have to see if a local camera repair shop can help you.
Wish I had more, but hope this helps.
Feb 05, 2011 | Olympus Cameras
Hi - I have an Olympus OM Zuiko 8mm f2.8 which I'd like to take the rear lens elements out to clean some fungus off them. Its not a bad infection and I have ammonia to clean them with. How do I get access...
Best of luck as good quality camera lenses are assembled in totally dust free environments. Even if you are to get the lens fully apart, the fungus may be not on but between one of the glass elements ( some are compound lens elements made of more than one piece of glass). You cannot disassemble a compound lens glass - a hammer works tho!. Not sure about ammonia but bleach is a good fungus/bug remover - but any chemical may well affect any lens coatings.
If this is the OM fisheye as I think, I would leave any repairs to a good camera/lens tech - too valuable to stuff up.
Dec 08, 2017 | Olympus Cameras
Problem for Olympus Zuiko? 40-150 mm f/3.5-4.5 Lens My viewfinder with this lens is dark. Other lens are OK
thats because its not a very good lens or its very dirty,,,tre looking at the light reading and shutter speeds with a similer lens fitted then put on the zuiko and see the difrence
Oct 13, 2009 | Olympus Zuiko 40-150 mm f/3.5-4.5 Lens
Lens Compatibility - Digital / Film
Hey savmoney,
Your current OM lenses are not directly compatible with the current four thirds mount used on Olympus DSLR's, but there is an OM four thirds adapter which should allow you to mount your older lenses to a new Olympus DSLR. You should have limited functionality while using the adapter, but according to the manufacturer aperture priority should work and full manual. I have included a link to a chart that shows which OM lenses are supported by this adapter. I hope this helps!
http://www.olympusamerica.com/cpg_section/cpg_files/mf1instcomp.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jun 26, 2008 | Photography
Can the 40-150mm be used in AF mode with EC14?
Tullio,
Olympus 4/3 adapter will work with OM lenses.
All in manual.
Manual focus, zoom and F stop.
atdlee@netzero.com
Jan 11, 2008 | Olympus 40-150mm f3.5/4.5 Zuiko Lens
Attaching non-Olympus lenses
The E-500 body has a "bayonet" twist & click attachment for the lens. There is no way that a simple screw threaded lens can attach to the camera directly. The lens that you have are designed to screw into the front of the original Olympus lens. I have seen some of these adverts on auction sites and they are worded something like "The wide angle / Tele lenses are simply mounted in the front of the Olympus EVOLT E-500 / E-330 / E-300 standard ZUIKO Digital EZ 14-45mm lens, or any other lens with 58mm filter thread." Which maybe isn't clear enough. So the bottom line is that you need an Olympus lens to use the other lenses you have bought. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Olympus EVOLT E-500 Digital Camera
Cameras Logo
121 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
