Question about Yamaha DVX-S200 System
System shuts off
The system is turned on and it says check SP and then shuts off. Please advise
Please advise on what to do when system turnes on and says check SP then shuts down
Posted on May 11, 2010
Can i hook up two 3 ohm subwoofers to the rt2500
Using 2 3ohm speakers in parallel is not advisable on this amp. 1.5ohms is too much of a load on the final. Use the speakers in series if your going to. (+) sp (-)(+) sp (-)
Mar 20, 2014 | RCA RT2500 System
This is a Unico AIR HANDLER in a residential application with heat / cool unit in the attic. With system off (not calling for cool) and fan in auto mode, the blower fan is on high speed only constantly....
Sounds like a sticking relay. You can check the stat simply by remove the faceplate. If fan still runs with tstat cover off its not the stat. Not sure is your blower has a separate relay or if relay is mounted on control board. This can be bypassed with a new relay if you are willing. Good luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 26, 2017 | Heating & Cooling
Playstation 3 stopped working. no standby lights at all. power cable is in the system secure. system has a burned out smell to it.
Please unplug your system immediately if you haven't already. Check your waranty if you still have the information, if not, estimate the timeframe you got the system and look up the waranty timeframe. Also check to see if the store you bought it from has a service plan on it. My reason for responding is to ask you to unplug it. DO NOT OPEN YOUR SYSTEM, this could void your waranty or any chance you have of getting it fixed.
Please be advised, I can comment on your testimonies.
1) Did you recently experience a power outage/surge? The system could have received too much and burned out.
2) Do you shut the system off from the back of the console? This is a very dangerous way of shutting off your system and could cause permanent damage to it.
3) Please let me know what you were doing on the last day it worked; any moving/rearranging, something causing involuntary power interruption, etc.
Sep 27, 2010 | Sony Playstation 3 (PS3) Console
System turns off when playing the gameboy sp games after about a minute or two it just shuts off like you turned the power off .It works fine when I play ds games but no matter what when you play a sp game...
I would open the DS and make sure all the wires are hooked up correctly in the bottom slot if they are then call Nintendo and ask if they could repair it.
May 09, 2010 | Nintendo DS Lite
Shuts off when turning volume up. Error message
go to a computer store and tell them to rebot your computer that what i did it worked for me it should probly work for u
Dec 18, 2009 | Yamaha HTR-5760 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Apr 23, 2009 | Yamaha RX-V757 Receiver
I have a fujitsu siemens amilo li2727 , i can't connect wifi (carte atheros ar5007eg) under xp sp3
I might advised you to check the driver of the wireless adapter using your computer. There are some issue about the operating system like SP 3, Check the driver if it is compatible to the operating system.
Mar 09, 2009 | Computers & Internet
Unit turns itself off after diplaying code "check SP wire"
My guess, guess, check CLOSELY the SPeaker wires - "Check SP wire" make sure all of the bare portion of the wire is into the terminal. No bare wire touching another bare wire both at the receiver and at the speakers. Also, if the wiring is not continuous, check all connections of speaker wire. Disconnect all but one, play it like that. If no problem, label that as good, disconnect another for several days, when one shuts Rec. off, check wires closely for that speaker.
Jan 23, 2009 | Yamaha HTR-5650 Receiver
Hi!
First you must check to see if you have installen the new system properly by checking all your conections..and that they are conected to the proper wires..the instructions provided for you frome the alarm companny will guide you..pay close attention when installing your new system as manny of the problems that occur are do to iproper instalation...hope this helps you...
Oct 20, 2008 | 1997 Mitsubishi Mirage
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
Yamaha DVX-S200 System Logo
111 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
