Question about Toro Lawn Mower With Toro Power Tools
My toro weedeater starts fine, but has low power. What is wrong with it?
    Problem Solver:
  • 12 Answers
Air fuel mix is off
Posted on Jul 03, 2009
Toro weed eater starts but then stalls out
A few things to check, clean or replace:
  • fuel filter - located inside the fuel tank
  • Spark arrestor - located at muffler
  • Spark plug
  • Carburetor
Mar 08, 2014 | Garden
Mower was running fine until I went on a incline .It stopped and would not start again. It has gas.
Check your oil level and condition. Most new motors have oil sensors on them that turn the motor off if the oil level is too low or in bad condition (old). If the oil level is low and you go on an incline the oil that is in the motor will flow away from the sensor and it will 'think' there isn't any oil in the crankcase and cut the motor off. The sensors are usually on the back side of the motor so going straight down hill will cause the oil to run away from the sensor, if it's really low sideways tilting can cause the same effect. If this is the cause the motor should start fine when level.
May 10, 2011 | Toro Lawn Mower With Toro Power Tools
I am trying to tune the carburator on the toro tc650 weedeater. need to know the turns on the low and high set screws
Turn them both all the way in. then turn them both out 11/4 turns.when tou start it you can fine tune it from there.
Dec 29, 2010 | Garden
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
May 16, 2010 | Toro Lawn Mower With Toro Power Tools
My mower starts and runs until the engine get hot.
the only way to test i think is with a known good coil or resistance check. also possible you need to check valve clearances
Apr 25, 2017 | Toro Lawn Mower With Toro Power Tools
Mower won't start. Toro mower..engine won't turn over. Cleaned sparkplug...checked air filter..weather cool. Followed instructions for cold engine...prime witrh three pushes of the bulb..wnon't even hint...
Something everyone over looks is oil. Did you check the oil? You seemed to mention everything else but. If you have a low oil switch with low oil it will not start
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Engine revs high then low then stops
check the governor lever. it prob sticking or gone.
Aug 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro electric weedeater
Your bearing in the head is going bad. Don't use or it will damage more componets. You need to replace. Hope this helps.
May 17, 2009 | Toro& Electric String Trimmer
Toro Lawn Mower With Toro Power Tools Logo
280 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
