Question about Roper RS22AQXKQ Side by Side Refrigerator
Older Roper side-by-side has been in storage for a few months, brought it in the house and plugged it in. After a day, the freezer is down to 34 degrees but the fridge is not getting cold. Both dials are set on coldest and the slider for the meat bin is open.
  • 232 Answers
Is the condencer clean, are both fans working, is the back cardboard cover still on it needs to be there set both controls to the middle of there range (factory reccomend setting) is it outside in the heat.
Posted on Jul 02, 2009
  • bill williams
    bill williams Jul 02, 2009
    olso check the gaskets all the way around the doors
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Side by side wirlpool fridge freezer not cooling down
make sure the fan motors are running. there is one near the compressor in the bottom rear and one in the freezer area. also be sure the compressor is running. being it was in storage there could be rust on the motors or possibly a mouse could have chewed through some wires.
Oct 28, 2008 | Whirlpool Refrigerators
ROPER RS22AQXMQ SIDE BY SIDE REFRIGERATOR PROBLEM
I had the same problem with a top freezer. I found that the thermostat was bad by tapping on the it at the setting knob. The defrost timer was replaced first which did not help (repairman put in a timer for a Frigadair which will not work in a Roper). If one is used for a frigadair as soon as it cycles it will not work again until it is unplugged and allowed to reset. I replaced both the thermostat and the right defrost timer. It has worked great for over 2 months.
Hope this helps.
Sep 10, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Jul 12, 2007 | Roper RT14DKX Top Freezer Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
69 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
