Question about Zoom (5590-00-03) Wireless Router (G66115)
How to connect an external antenna (high gain) ? to the X6 ?
Hi, and thanks in advance for your help,how to detach the antenna from the zoom adsl X6 ? it seems it is un-detachable.
  • 306 Answers
Re: how to connect an external antenna (high gain) ? to...
Well you can always break it off but its not recommended...why do you need to remove it?
Posted on Nov 10, 2007
0 characters
3 Points
Can i use my zoom x6 model 5590 adsl wireless router if i have i dont have a house phone? my internet is used through my cable
yes there is one way if you dont have a house phone. if you have a cellphone turn it on and put it on top of your machine.
Jan 03, 2011 | Zoom X6 Adsl Wireless Gateway Rohs Router
Low signel strength
Common with single antenna routers and adsl/router boxes, i use a zoom x6 adsl with wireless and i was having similar problems , it also has a single antenna so i disabled its wireless feature and got a linksys rangebooster router dedicated to my wireless needs, has good range and its durable, Im basically suggesting that you get another wireless router with dual antennae and use that for your wireless needs, hook that up to your DLINK modem via ethernet cable and disable the dlink's wireless feature...Hope this helps..
Oct 27, 2010 | D-Link DSL-G604T Wireless Router
Hi, I set up my router a while back, but it's giving me problems now. I can't remember my user name an password so therefore I can't resolve my router issue. Router type: Zoom X6 Ver 5.0.8-00...
Simply re-set the Router, and login as default user, and set it up again, as there is NO WAY to recover these passwords, unless you remember them :(
Above is your manual download link, it is all explained in there.
Aug 04, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
i have lost my disk , and have to reload zoom adsl x6 is there a download
Jul 03, 2008 | Zoom (56600000) Router
Zoom wireless router
Just tell it your new username/password under basic setup
Jun 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Problem with password change
Check your manual if you have the option to change your password. Also try if there is a reset switch; dont do thiese unless you have properly noted down settings particular informations on ISP for your ruter to connect properly again.
Dec 23, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom X6 5590
By default the ip address should be set to
user name admin--lower case
password admin--lower case
and go to wire less settings and change the channels there>and save it>and reboot it>and rate me solvedif its helps thx
Nov 24, 2007 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zoom (5590-00-03) Wireless Router (G66115) Logo
191 people viewed this question
Top Zoom Routers Experts
 C. Dante
C. Dante
Are you a Zoom Router Expert? Answer questions, earn points and help others
