Question about Panasonic Microwave Ovens
Looking for a operating manual for a panasonic " gemini bake&broil" microwave
  • 4,472 Answers
Do you have a specific model number for the microwave? Once I have that I can help locate a manual.
Thank you,
Lee
Posted on Jul 02, 2009
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
Panasonic 28 L NN C784 MF Cov+BAke. Turns off automatically after 20 secs every time. It once displayed HOT message too. Even after 24 hours of last operation the MW turns off automatically after...
hi,
look in the back through the grille with a flashlight to see if the cooling fan is running, you should feel a slight draft there too. if not running take the cover off and oil the magnetron cooling fan with 3 in1 sewing machine oil. oil it on both sides of the motor so its saturated. if it does it again you will have to order that motor. probably at panasonic.com or searspartsdirect.com. be careful inside the microwave with the cover off, avoid the red high voltage wires. use gloves if necessary. panasonics are a pretty good oven, worth fixing..
jm
Apr 25, 2011 | Panasonic NNH965BF Microwave Oven
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
When oven is in on postion oven element does not come on but broil element does;when in broil position nothing happens and indicator light is dim when in off position but burns bright when in oven...
sounds like you have a bad control board.or you have crossed the broil element wire witha bake element wire.these are the first things to check
Jan 22, 2010 | Microwave Ovens
Microwave Manual
You can get the manual for this model here:
www.chsinteractive.co.uk
Sep 27, 2009 | Panasonic Microwave Ovens
Microwave sparks on the inside
It sounds like it needs professional servicing. There may be an issue with excessive radiation escaping from the oven -- this could be dangerous. Can't say for sure, but were it my oven, I would take it to a shop with the equipment to test for this condition.
Charlie
Aug 23, 2009 | Microwave Ovens
Microwave Ovens Logo
85 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
