Question about Viking Professional VCBB363SS Stainless Steel Refrigerator
Need photo of Defrost Switch or Sensor
REPLY to "fixit 4 ya" - Checked continuity on heater coil using ohm meter and result was negative (no continuity). I guess the heater coil has a break which is why freezer is not defrosting. Is the defrost sensor the flat silver piece? How do you check if it is good? Ran ohm meter across it and its result is negative as well. I don’t know anything about refrigeration, but I’m guessing when the freezer builds up ice on the heater core the freezer temp either gets colder or warmer. Whichever it is the internals of the defrost switch will make contact and send current to the heater coil which then heats up and defrosts the ice. Once the temperature goes back to whatever the defrost switch is set for, the contacts will open thus turning off the heater coil. Is this how this system works? I haven’t read anything on defrosting so I’m just guessing.
SUGGESTION FROM fixit 4 ya -
Before replacing all of the components mentioned above, locate your defrost heater and check for continuity with an ohm meter,this will ensure no breaks in heater coil
Need photo of freezer defrost sensor, switch or thermostat Anyone have a photo, of the freezers defrost: switch, sensor or thermostat? Also, how to check if these parts are More
Anyone have a photo, of the freezers defrost: switch, sensor or thermostat? Also, how to check if these parts are working and how to order replacement part. Frost keeps building up even after manually defrosting. I removed the back plate and defrosted with a hair dryer twice now. After 3-weeks the frost builds up again. I have not seen any water in the defrost pan so the unit is not defrosting.
  • 64 Answers
Unit needs to be cold when you test. it closes at around 20 or 30 degrees F and opens around 55 deg F
Posted on Jul 02, 2009
I have a Maytag PTB1953DR refrigerator, would the timer be shot again?
The timer should last a lot longer than that, but I have received bad ones right out of the box. Depending on model year, the full current of the compressor and the defrost heater are present in the defrost timer contacts. The defrost heater should be checked with a volt-ohm meter if continued icing takes place. The defrost heater will have a positive ohm reading if it is okay. If the meter reads infinity or 0.0 ohms, the heater is bad.
Apr 23, 2015 | Maytag Refrigerators
I have a GE Profile refrigerator model #PFSSPKXBSS and the front control panel gets frozen. The only time I can change the settings is when the display panel goes haywire and starts changing all the...
solenoid for the ice dispenser flopper might get rusted, so the flop door would not close and freezer air would escape building up ice. need new solenoid assy for ice dispenser door and possible flopper.
Mar 27, 2015 | GE Refrigerators
Fixya manuals
It doesn't defrost
  1. Defrost control board
If the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  1. Main control board
A possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  1. Defrost timer
If the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  1. Defrost heater assembly
If your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  1. Defrost thermostat
Another cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  1. Defrost sensor with fuse
Another possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Defrost drain problems
  1. Clogged or freezing defrost drain
If you are experiencing defrost drain issues, it is possibly due to a clogged or freezing drain that is blocking water flow to the bottom of the freezer. This will cause the defrost water to drain and drip down to the bottom of the freezer section. To correct this issue, thaw any ice or remove debris that could be causing the clogged drain or replace the drain heater.
  1. Drain heater
If you are experiencing defrost drain problems, inspect the defrost drain heater. A dislocated or burnt out drain heater will result in the drain tube freezing over. Attempt to return the part to the designated position or replace the damaged part to correct the issue. Search Over 2 1 Million Appliance Parts
Sep 06, 2014 | GE Monogram ZIRS36NM 36'' Stainless All...
Samsung RS265LBBP Defrost Thermostat
Try to check the thermostat by heating slightly with a hair dryer. It should give an open circuit once heated slightly. Have you checked the heater. You may have an open heater. Ohm out the heater it should give a reasonable low ohm reading. If the heater measures in the k or m range it is bad.
one other thing to answer your initial question. The thermostat is likely not the cause. If you have continuity that means power can go to your heater circuit.
Good luck
Feb 25, 2014 | Samsung RS265LBBP Side by Side...
Ice forming on bottom of freezer compartment Samsung RF4287HARS.
dont worry about it, you probably didnt get the freezer drawer closed all the way. frost will form when it doesnt get closed properly. just make sure it is closed now and the unit will clear the frost in a few days thru normal defrosting cycles. be sure that the drawer is closing on all sides by looking at the gasket and all should be ok in the future.
Nov 02, 2013 | Samsung RF4287HARS French Door...
Neff integrated fridge freezer
test this steps and fix it, use the VOM. God bless you
  1. Defrost control boardIf the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  2. Main control boardA possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  3. Defrost timerIf the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  4. Defrost heater assemblyIf your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  5. Defrost thermostatAnother cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  6. Defrost sensor with fuseAnother possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Read more: http://www.appliancepartspros.com/repair-help/refrigerator-repair-help.html#9#ixzz2aX5nUL00
Jul 30, 2013 | Refrigerators
Frigidaire will not defrost
When a refrigerator will not defrost their are 3 components of the defrost system that could fail and won't allow it to defrost.
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST TIMER.... it will be located in the control panel in the ref.section and not in the freezer,it has a center hub that can be turned using a straight blade screwdriver,turn it slowly until ya hear the compressor and fan in the freezer shutoff and then within 5 minutes IF the defrost timer is defective the defrost heater will be on,if when turning it and ya wait 5 minutes and the heater does not come on either the defrost heater or thermostat will be the problem and they can be checked as stated above.
Oct 10, 2011 | Frigidaire Refrigerators
Self defroster is not defrosting. Changed timer with no luck.
Remove the freezer back panel and replace the defrost heater and defrost thermostat.
Jul 25, 2011 | Refrigerators
Jun 29, 2009 | Viking Professional VCBB363SS Stainless...
GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Viking Professional VCBB363SS Stainless Steel Refrigerator Logo
852 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
