Question about Acer Aspire One AOA110-1588 Notebook
Doesn't detect at bios.
First is detect at windows, and when tomorrow i got it turn on, it doesn't detect at all even in bios. is it broken or anything.
by the way this is the hardisk of acer aspire one (10gb)
  • 4,472 Answers
I am having a little trouble understanding your exact problem? How long ago did you purchase the unit. It sounds like your hard drive may be failing, but much more information is needed to give a better and more helpful solution.
Thank you,
Lee
Posted on Jul 02, 2009
  • 40 Answers
You had better give it for servicing, it can be anything. Try to install the OS again. Just in case it's some problem with os.
NR serise wont detect hdd in bios
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 04, 2012 | Sony VAIO NR Notebook VGNNR460ES
Toshiba l450 h.d.d unable to detect from bios
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 23, 2012 | Toshiba Computers & Internet
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
Turn on acer laptop and it goes to black screen that says no bootable device
Feb 16, 2012 | Acer Aspire Computers & Internet
I can not get past the blue screen unmountable_ boot_ volume even in safe mode.
You Dell Latitude cannot detect the hard disk.
Feb 16, 2012 | Dell Latitude D505 Notebook
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
Laptop is not detecting the CDs or DVDs
check your CD/DVD driver is properly installed. you can check it by going in control panel, Clean your CD/DVD drive by any Cd/DVD cleaner.
Jul 06, 2011 | Compaq Computers & Internet
Bios cannot detect hard drive suddenly. I was running the PC well. Trying to start the PC again, cannot go into windows. Check on the bios, no hard drive detect.
Follow the steps given below.
1) First, check your hard disk cable, I recommend you to replace the Hard Disk Cable.
2) If the BIOS doesn't detect your Hard Disk after replacing Hard Disk cable try upgrading your BIOS from the Dell website.
Jul 06, 2011 | Dell Studio Xps 9100 Desktop Computer
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
Inoperative keyboard
Keyboards are pretty standard, I've even gotten old AT style keyboards to work. If it can't be detected by your computer I would suspect either a bad port or a broken keyboard. The exception would be USB keyboards. They have to be enabled in the BIOS and even then there can be a short delay before they are initialized by the system.
Sep 16, 2008 | Microsoft Windows XP Professional
Acer Aspire One AOA110-1588 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
