Question about Seville Classics MSC10166 Tower Fan
The fan fuse 1.5A/250V is keep blown up as soon as
Sevile classic MSC 10166 fan fuse (1.5A/250V) is keep blown up as soon as I change new one. It shorts somewhere.Please tell me where to start. Thanks. Mugong
  • 67 Answers
Unplug the fan.
Open it up carefully.
Look at the the wiring for damage or shorts.
Check that the fan impeller is free to turn.
If all of the above is OK then possibly the motor has gone? If so then it will probably be cheeper to buy a new one.
Posted on Jul 02, 2009
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
The previous owner put a 250v receptacle but it only had a 120v at the receptacle. Now I own it. So I fed the unit with 250v as it should be. Now when I turn it on f-2 fuse blowns as soon as I turn the...
The receptacle does not change the voltage rating of the machine.
For safety this machine had a moulded plug as it should be wired for L1 and L2 with an `Earth.
I would get a qualified electrician to advise you whilst testing the machine.
Nov 17, 2017 | Miele CVA610
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
Wiring for 1989 cadillac sevile heater fan doe's not turn on 4.5 v-8
If the fuse is ok, then replace the blower motor and the blower motor resistor pack. This was the only cause I have ever seen on those cars.
Sep 21, 2012 | 1999 Chevrolet Lumina
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
MY JBL SUB135 IS BURNING OUT THE 2.5A 250V TYPE T FUSE
Something is shorted on the circuit board, could be anything - switcher power transformer, rectifier diodes (or a bridge), resistors, blown, dried, leaked or shorted electrolytic capacitors in the power supply section, possibly any other shorted components in any other section.
If you're lucky, there will be visible damage to the faulty component, otherwise you will need to measure the components to find a short.
Anyway, it could be something as simple as a shorted diode or resistor in the power supply section, but i can't say anything for sure.
Hope you can get it fixed...
Regards
3rq8 (Triarcuate)
Sep 04, 2009 | Audio Players & Recorders
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Seville Classics MSC10166 Tower Fan Logo
1,018 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
