Question about LG Microwave
I have nationl mocro wave
The problem is the start button and the stop button have stopped functioning
  • 67 Answers
If it's under warrenty guarentee, then take it back to where you bought it? If not, all you can safely do is to check the fuse, if OK, buy a new one. - sorry
Posted on Jul 02, 2009
Micro wave oven works for approx 5 seconds than stops
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Nov 14, 2013 | Microwave Ovens
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Oct 20, 2013 | Kenmore 63662 / 63664 / 63669 Microwave...
How do i set the clock on my hinari life style micro wave mx698tcss
Usually one must press the cancel/stop button before setting the time by pressing the clock button and pressing hour/minute buttons and then clock again to memorise it.
Jan 19, 2011 | Microwave Ovens
Frigidaire PLMV168K2 micro wave stopped heating food. Still has turntable and light functions. Seems to have more of a power load after initial start. The buzz is more intense than normal.
A loud buzz is a symptom of a shorted magnetron or high voltage diode. Would recommend that you take it to a qualified repair facility if you want it repaired, but if the magnetron has failed, the part costs can equal that of a new oven.
Dec 06, 2010 | Frigidaire PLMV168 Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Oven stopped working except for the "express" button.
hello,
what is indicate i that there is a form of disconnection or loose of wire from the connection on the element i.e the heater it is silver in colour
what you have to do to fix up wave back to function is to (unscrew)open the wave then trace the wire down to the element to fine the loose wire then connecte it back to the element and then make sure there is no form of dirt or liquid form on the panel of the wave couple it back with this the problem is solve .
please when doing this put off all power supply connected to the wave.
than you and thanks for using fixa.
Jun 14, 2010 | GE Advantium SCA1001SS Convection /...
I cannot press start and stop button i think sensor is not working i can press rest 1234567 button n not 890 n start n stop button
Normally, it suggests the keypad is faulty. The fact that you have part function indicates the board is functioning. Replace keypad.
May 28, 2010 | Sanyo Microwave Ovens
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
LG Microwave Logo
42 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
