Question about Motorola Talkabout T6210 (14 Channels) 2-Way Radio
One of the T6210 radio will send and receive. The other will send but not receive
  • Motorola Master
  • 1,654 Answers
The one which will not receive possibly has a different interference eliminator code from the first unit. Check your programming. Your freq., code and Qt filter (if any) must match identically. If everything matches and you still cannot receive, you have a bad radio.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T6200_User_Manual_E.pdf
Posted on Jul 03, 2009
One walkie talkie will send but not receive
Check your programming, specifically the private line (PL code) settings. This is one problem which can cause the problem you are describing.
Feb 22, 2014 | Midland Radio Midland Gxt 795 Vp4 Radio...
Cobra frs 104
look in the battery compartment for a series of tiny switches under the batteries.. these switches must be identical for each radio..it puts them on the same frequency..then select channels with no interference..retry radios..
Jan 26, 2014 | Cobra FRS 250 (14 Channels) 2-Way Radio
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
Are motorola talkabout t6210 and talkabout 200 compatable. I have the eavesdrop reducer turned off on the t6210 but the transmissions are garbled when recieved by the talkabout 200.
Yes, they should be compatible. You are correct in shutting off your eaves drop reducer. You might also check to see you have your interference eliminator code set to zero (off). We have been unable to find a good online source for a user guide for the T200, but if memory serves, they do not have "code". Here is a link to the very similar T280 guide: http://www.giantintl.com/ContentManage/manuals/Moto/T280_User_Manual.pdf
And here is a link to the T6210 user guide http://www.giantintl.com/ContentManage/manuals/Moto/T6200_User_Manual_E.pdf
Between the two radios there should be 14 frequencies in common. If you continue to have difficulties you might check to see if your batteries are good and/or fully charged. This also can interfere with good communications.
Best regards.
Aug 22, 2010 | Motorola Talkabout T6210 (14 Channels)...
One radio only sends, it can't recieve
check the privacy CTCSS code in menu
Apr 07, 2010 | Radio Shack 21-1926
The working frequency range for talkabout T6210
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placementof your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see.
Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
May 30, 2009 | Motorola Talkabout T6210 (14 Channels)...
Scratchy Transmission
The first thing which comes to mind is a bad battery pack. You might try switching the batteries between the two units and see if the problem moves to the other unit.
Secondly, if you only have two radios, it could be the opposite radio has poor receive. You could have a damaged or defective speaker in the receiving unit.
Third, check the speaker grill and mic holes on both units to see they are clear of debris.
If all these items check out, you may need to eventually replace the defective radio. However, to determine which one is defective by trying them with a known good radio.
Jan 13, 2009 | Motorola Talkabout T6210 (14 Channels)...
Turning unit on
It sounds like you may have internal corrosion damage, possibly from the battery situation or from having been damp at some time. If cleaning the battery contact with a pencil eraser doesn't do the trick, you are out of luck. This model is not repairable, as parts and schematics are not available, it would need to be replaced. Here is a link to the owners manual http://www.usersmanualguide.com/motorola/2-way_radio/t6210
Sorry we did not have better news.
Oct 16, 2008 | Motorola Talkabout T6210 (14 Channels)...
Motorola Talkabout T6210 (14 Channels) 2-Way Radio Logo
316 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
