Question about Dell Samsung Notebook Np-n130 Mini Wireless Card Cnba59
My samsung np130 got damaged by a hard slap to the lid while I was using it. Since then, it won't boot, it goes until it says "windows is loading files,' then the progress bar loads quickly more than
..actually, nowhere on the unit is "dell" mentioned....;P
SOURCE:
melnavz
  • 1226 Answers
SOURCE: My Dell 4500 will not Load Windows XP
Hello.
In addition to igbal solution. if you found out that the memory is good and the bluescreen still excess. i will suggest you to reinstall the operating system im sure this will resolved the problems. melnavz
Posted on Mar 24, 2008
techniwiz
  • 275 Answers
SOURCE: ''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Posted on Nov 11, 2008
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
Holygrass
  • 443 Answers
SOURCE: my laptop is giving the
Click on the link below for the Resloution.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&l=en&s=dhs&docid=DSN_126A722713F6D0D0E0401E0A55174AE6&isLegacy=true
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Posted on Jan 09, 2011
shibuda
  • 1812 Answers
SOURCE: my dell latitude e5400 will start up but will not
You did not post exat error ,I think Windows OS can not detect the sata hard disk.You can set up the bios for set drive sata to IDE ,or you can make the Windows cd, along with the ACHI driver for detect the sata Hard disk.
Please follow the bellow link .
http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/
OR can do another way.
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Posted on Jan 17, 2011
Need help - black screen on Samsung 700A3D
Looks like the boot manager file could be damaged or a driver is missing. Use your windows disk to boot from and choose the repair option.
Aug 31, 2016 | Samsung Computers & Internet
How to tell if a hard drive needs replacing on a samsung r519
1. If you have blue screen give us the exception code (0x000000) 2. How did you get to this point? 3. What is the condition of you install disk? Windows setup could just be messing up because the windows disk is damaged. Find an OEM copy of windows and set it up to boot from flash drive or external drive (CDs at prone to damage if you want a reliable windows install only use optical media if its in pristine condition.)
Jul 28, 2013 | Samsung R517 R518 R519 R522 Laptop Lcd Led...
Hi, I have a Toshiba Satellite A665-s6055 laptop. I can start it up but it won't load Windows. It just goes to the Windows load screen, then to a black screen with my cursor. Also, I can't start...
The hard drive could be slightly faulty. Try this first.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
May 06, 2013 | Computers & Internet
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Slam lid on laptop, now it won't boot.
Sounds like you have damaged the hard drive. Just because you can read the files doesn't mean that the hard drive is not damaged. You may have corrupted a particular part of the data when you gave it a jolt. My suggestion would be to find a laptop that is the same and try the hard drive, or buy a new hard drive and see if that fixes it.
Feb 11, 2013 | Computers & Internet
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Can not boot. diagnostics indicate drive failure. the failong drive is a samsung sp2004c hard dive in a compaq SR1920 NX desktop. Even in safe mode it goes as far as loading disk drivers and stops at multi...
You seem to have a boot up error. you can try using the derive as a second HDD on another PC & reformatting. if it fails, sorry to say your HDD is faulty, if you have warranty ask for a replacment
Mar 28, 2010 | Samsung SpinPoint P120S (SP2004C) 200 GB...
Dell 4550 unmountable boot volume error.
0) Your hard drive is corrupted by improper shut down,
or the hardware may be physically damaged by
by a power spike.
1) Reboot the machine with hard reset, and press the BIOS
key during the memory test.
Typically this is the DEL key most machines but it could
be F1 or some other key, so if DEL does not get you into
the BIOS, check you system manual or experiment.
2) Once you are in the BIOS settings screen, look for a
TAB or settings page for changing the BOOT priority
for installed devices.
3) Make sure that your CD-ROM drive is FIRST in line, before
the hard drive, but leave the hard disk boot enabled
4) If you do this correctly your system should firs try to boot
from the CD, and only try the disk if the CD is not in the
machine.
5) Now reboot the machine from the original Windows setup
CD, and let it do its thing, until you get to a prompt
asking you id you want to RE-INSTALL Windows or
try to REPAIR the installation using a RESCUE DISK
for now, choose INSTALL, and accept the user license
contract.
6) Proceed with the installation (only) until you get another
prompt, asking you if wish wish to repair the system
using the
WINDOWS RECOVERY CONSOLE
7) Chose the recovery console !!!
(do not continue with a new install)
8) After windows finishes loading, you will be looking
at a black and white text screen, similar to DOS.
9) You may have to login with the administrator password.
10) If your master administator password is lost or unavailable,
and if you are using windows XP, try to get it with
and older Windows 2000 installation disk instead,
This should get you beyond the windows XP password
security and function the same as XP.
11) Once you are logged into the recovery console, you
can try to repair the master boot record on the damaged
disk:
12) Type FixMBR at the command prompt
for more info read this Microsoft article:
http://support.microsoft.com/kb/314503
13) If this does not work, then the Windows partition is
corrupt. The problem is that most tools needed to repair
NTFS require Windows to run, and Windows will NOT run
if the boot partition is bad.
14) To get around this problem, you can install a second
hard drive in you machine, and install a parallel copy
of windows on it.
or if your existing drive is partioned, you could use
a tool like Norton's Partition Magic to adjust the partitions,
such that you could make a new partition for the parallel
copy of windows there, put keep in mind that you Partition
Magic will NOT alter any partition that is damaged, so
you may have a Catch 22 situation.
15) Once you have a parallel copy of windows installed on the
machine, you can use a multitude of tools to try to repair
the damage hard drive, MBR, partition tables, partion boot
records, the file system ... etc
At this point you can also replace key windows system files
by copying them over from good windows to the bad.
16) There are also (expensive) commercial utilities for
recovering corrupted disks. NTFS is more expensive to
recover than FAT
17) Finally is non of the above works, you can sent your
drive back to the manufacturer or a professional
recovery lab, this cost $2000 to $3000 though.
18) Not all drives can be recovered fully, depending on how
bad the damage is.
19) If the hard-drive electronics are damaged from a power
spike, it is often possible to service the hard drive by
replacing its circuit board, from an identical model,
because the data is probably still intact. An electronic
tech can easily do this. This is cheap.
20) Always run you computer from a UPS, uninteruptable
power supply (battery backed up) to prevent such
problems in the future.
Hope this helps
Martin
Jun 08, 2008 | Dell Microsoft Windows XP Home Edition
Dell Samsung Notebook Np-n130 Mini Wireless Card Cnba59 Logo
42 people viewed this question
Clive
Clive
Alun Cox
