Question about Clarion M475 CD Player
Volume issues with clarion M309 installed on a boat
Just installed a Clarion M309 head unit in a boat connected to 4 older clarion 6.5" speakers. My first problem is max volume on the unit is 33 but the unit needs to be at 14 just to hear sound. The second problem is if I get above 25 on the volume the speakers sound like they fade in and out or cut in and out(don't know the terminology) and the led "pulses" with the bass. I do not have an amp hooked up to the speakers. The only info I can get on the speakers is that they are 100W max power rated and the head unit puts out 50W x 4 RMS. I hope the only issue is that I need an amp to push the speakers but I want to be sure before investing. I am a newbee and any help would be greatly appreciated.
  • 655 Answers
Hello jcox7704,
Your head unit is 50 watts X 4 channel maximum power and 21 watts RMS so it's possible that all you need is more power to the speakers. But even 21 watts RMS should be enough for normal speakers. Before investing in an amp, I'd check the speakers and their wiring. Measure the impedance (resistance) at the head unit side to see if they match up.
Hope this helps.
Posted on Jul 02, 2009
Speakers stopped working. Unit seems fine except no sound.
Have you tried another set of speakers and wired directly to the unit? If yes, then the internal amp may have failed or a failsafe shunted. Try resetting the unit.
If all else fails, I recommend contacting Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
Jun 27, 2015 | Clarion CMS1
In my boat is a Clarion CMD6 head unit with two rear CMQ1620R speakers, it distorts at medium to high volume, you cant turn it up load when going.Wishing to put two new speakers in the front, cannot cut...
Best bet is to take your boat to a qualified Marine Audio dealer (generally not a boat repair shop or marina), or to a good quality Car audio store that is insured to work on boats (separete insurance usually).
When it comes to boats, you need lots of power and speakers.
First thing to do is make sure what you have is properly installed. Then determine what is "distorting" .. is it too much base, purely volume or what.
Most boats we do (wakeboard style and river boats) we do: 40-75 watts RMS per speaker 4-6 speakers in boat 1 10" or 12" sub with 200-300 watts RMS Tower speaker if requested with 75-125 Watts RMS per speaker
Feb 06, 2011 | Clarion Car Audio & Video
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Jun 10, 2010 | Clarion XMD3
Clarion M335 display and CD work - suddenly no sound
Maybe it is a boat anchor. Recommend contacting a local car audio professional or Clarion customer support directly here:
Aug 14, 2017 | Clarion M335 CD Player
Clarion APX480M amp
This sounds like a signal problem. Make sure that all of your signal cables are plugged in fully. If all are, you need to check for coninuity between the shield ground of the head unit's RCA jacks and the case of the head unit. With no RCAs plugged into the head unit, you should read ~0 ohms between the shield of the RCA jacks and the case of the head unit.
Aug 28, 2007 | Clarion APX480M Car Audio Amplifier
400 watt amplifier not working
Disconnect all the speaker wires from the amplifier that runs the 6-speaker system. Switch off the amplifier or disconnect the remote turn-on wire, then re-connect it. Does the power light still flash with no speakers connected? If so, your amplifier is probably damaged. If not, then connect one speaker and see if it plays. If it doesn't, disconnect the first speaker and connect a different one. If the first speaker plays, continue connecting the rest of the speakers until you find the one that's causing the problem.
Mar 05, 2007 | Clarion APX401.2 Car Audio Amplifier
Clarion M475 CD Player Logo
717 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
