Question about Samsung X15 Notebook
How do I open the Samsun X15 to replace the power jack?!!! Help!
I have tried everything, unscrewed every screw on the back but it just won't come apart. Is there some kind of special key I need? because on the back I can see a little hole and a sign next to it, wich looks like a pic of a chain, I am imagining I need to put a key in there.
Please help if you can,,,,
  • 1 more comment
  • chilli_ppr Nov 11, 2007
    Hi Poohawk,
    thanks for getting back to me... its the bottom part, where you have all the bits like memory, hard drive, etc.
    Hi Poohawk,
  • Anonymous Mar 31, 2009
    my power jack is also faulty. no charge up or any signs of life. i too was told to go into the top of the laptop..but beware that it may be mounted on the motherboard..which made me a little it mounted on a seperate board and is it a common, easy to replace thing or does it mean there are other assosciated probs?
The power jack inside of the toshiba satellite 2455-s30x is NOT soldiered to the motherboard!! WOOHOO!! It actually sits on a set of rails. It easily slides out and is removed from the motherboard with a snap. Very simple and easy to replace. I know, because I have a 2455-s305 and mine just broke! I got it out, and was super happy to see that it is not a part of the motherboard. Now where do I get one?!?!
Posted on Dec 27, 2007
  • 324 Answers
Hey there chilli-
Nope, you don't need any key that I know of. Need to have a little more info just so we are on the same page. You said that you took out every screw on the back. What part of the system are you trying to get into? Are you talking about the back (down below the screen) or are you talking about the bottom?
Posted on Nov 09, 2007
  • Ron Roske Nov 11, 2007
    Not real familiar with that particular laptop, but here goes. To replace or resolder the power jack, you'll have to pull the system board (motherboard). To pull the system board, you'll have to pretty much totally disassemble the laptop. Now that you have all of the screws out of the bottom, you'll need to remove the keyboard, touchpad, and everything else that is on the top of the base. After removing those items, you should be able to get to the system board. There may be some screws on the system board that will have to be removed, also.
    Kind of a generic description, I know, but that should get you to where you want to go. Just be sure to keep track of which screws go where. Replacing the wrong length of screw in the wrong place can cause all kinds of consternation!! ;o)
    Hope this has helped and best of luck!
Install new power jack in asus u50f rbbago5
You need to have it done with an experienced technician... but if you really want to do it yourself, Please download the service manual of the Laptop model you have.
You gonna open the laptop by removing multiple screws, locate the power jack and do some repair or replace the power jack.
Please follow service manual on how to unscrew and open your laptop.
Feb 23, 2015 | ASUS Computers & Internet
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
How can i replace a power jack on an acer aspire 7738 laptop
I actually just did this. I took some pictures while I was at it.
Problem in my case was a bad contact, leading to flickering of the power light, and me having to twist the power cable until it powered again.
I mostly followed this youtube post:
However, there was no need to remove the lower screws on the back, or to detach the keyboard or anything else. Just have to take off the "tuba" cover, unplug the power, unscrew the screen, screw open the screen (really the hard part!! Takes alot of force to get it open (dangerous)), and then finally the power jack replacement.
I ordered a new one from ebay for 5 bucks.
Hope this helps
replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-1.jpg replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-3.jpg replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-6.jpg replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-10.jpg
Oct 05, 2011 | Computers & Internet
probably when the power jack was being changed, a connector cables was mistakenly tampered with,
therefore in order to fix this, try to unscrew the laptop, check all available cable that makes a connection. once you sight the cable that was tampered with, connect it back to its normal place, screw thelaptop back together then turn it on.
Jan 02, 2010 | Acer Aspire 9300-3716 Notebook
Tech manual for Asus Z96J lap top. need to replace the dc power jack how do I access the power jack?
For all the function and portability laptops provide, there are also some drawbacks. The biggest problem with laptops is with battery life. To get constant battery power, the laptop has to be plugged into a wall outlet. The wall plug then connects to the DC jack in the back of the laptop. The DC jack is no more than a little piece of metal that conducts the electricity for the computer. These DC jacks are known to be fragile and break off easily. If this happens, you can open the laptop and replace the DC jack yourself.
  1. Step 1 Remove the internal battery pack from your laptop. Flip the laptop over and locate the release button for the battery pack. Hold the button in to slide the battery pack free. It is important that you remove the internal battery pack as well as unplug the power cord from the wall outlet to prevent risk of shock while working inside the laptop.
  2. Step 2 Unscrew all of the screws on the underside of your laptop. The number of screws will depend on the model of computer. There should be one at each corner and then one or two screws that hold the hard drivemag-glass_10x10.gif cover in place. Once the screws are removed, take out your computer's hard drive. Newer-model computers will have a hard drive that slides out of the side of the computer.
  3. Step 3 Locate the two screws at the back of the computer that hold the laptop screen's hinges in place. Once these two screws are removed, gently pull up on the screen until you clear the silver pegs from the holes in the laptop's body. Two wires lead from the screen into the computer, so ensure you do not pull so hard that you disconnect them. Carefully set the laptop screen aside so it does not get damaged while you work inside the computer.
  4. Step 4 Separate the two halves of the laptop's body to expose the computer's internal components. Flip the keyboard on its face, making sure not to disconnect the keyboard's connector. Underneath the keyboard will be a metal plate that covers the computer's motherboard. Unscrew the screws that hold this plate in place and set it aside.
  5. Step 5 Locate the DC jack for the laptop. Most all laptop's DC jack outlets are located at the back left corner of the computer. Using your tweezers, remove the old DC jack. Identify the slot in the motherboard that the old DC jack came out of. If the DC jack was loose before you removed it, there will be a small slot at the base of the opening in the back of the computer that the DC jack pops into. Using the tweezers again, slide the new DC jack into this slot until you hear a clicking sound. To hold it in place you can solder the new jack to the motherboard, or simply superglue it in place. Don't use too much superglue or you will risk losing the ability for the jack to conduct electricity.
Nov 14, 2009 | Computers & Internet
How do i replace my screen?
you will have to take the phone completely apart, and you will most likely need special tools to open it. unscrew all screws you find, there could be hidden screws under soft objects and labels.
ones you have the screws out the case should snap open from the corner, with the help of a flat screwdriver.
ones you have the case apart, you will need to unscrew and disconnect the display. then replace it with a new display, and put everything back together.
all you need are the tools, maybe some special screwdrivers etc and you can do it.
Jun 07, 2009 | LG CHOCOLATE VX8500 Cellular Phone
How to disassemble a Gateway 7330GZ Laptop?
hi I have just repaired my gateway 7330 it has a structure similar to m520s and many other e machines (power jack and battery problem) now it is even charging :O I was about to order jack but just iron soldering worked fine here is step by step I can help anyone through my email, I am living in maine I can even repair for free
you should get the screws out at the back of the pc all the way
take out the harddisk before you start
pop up the two things from the back of the lcd
pop out the power and volume panel
unscrew the keyboard
unscrew the metal panels
(you should take out two cables from wireless adapter before while unscrewing the back side so it wont bother you it is easy to plug and unplug)
lean the lcd all the way back and unscrew underneath the lcd 4 screws
there are still two screws under the lcd area to the left unscrew them if you see them
take out the dvd writer
unscrew any other places that you find on the motherboard
there is a lean point(the metal long thing screwed to motherboard around beneath the left windows key take it out too)
take the card reader out by unscrewing 2-3 screws
thats all I remember
after unscrewing and taking all the pieces out
try to pull the mainboard from microphone speaker input
(unscrew any other remaining screws if you feel any pressure)
with a screwdriver try pulling from the input and the left of the keyboard pull the mainboard but be careful
create a little space that you can work with the dc input
the most inportant ones are the two in the middle
try to concentrate on the one that wore most
take the old solder out by your soldering gun or whatever
and then put new ones in carefully
put all the stuff back (whenever I do it I almost always have afew more screws than I am supposed to whatever it works)
be careful pulling the keyboard cable and other similar cables (they have a bed which can be opened dont just pull it) pull the bed upwards and open it and then take it out do the opposite when putting it all back
thats all no matter what other people say I love this pc I love p4s
gateway is better than ok (you should have seen my acer)
Oct 29, 2008 | Gateway Computers & Internet
"Burned" DC in power adapter
hi there generally all laptops can be opened more or less in the same way first undo all screws in the back, next you need to remove the panel where the power button is most of them just unclip and come off easily using a flat screw driver, you'll probably find some more screws underneath,if the hinges covers are part of the panel they should come off with the panel if seperate just check for any screws if not they just unclip undo any further screws, next unscrew the keyboard, unplug it, unplug the mouse pad, then the top part of the laptop base should just lift easily, make sure you remove the battery before you start all this, any drives, hard drive, etc hope this would be of some help regards
Jun 21, 2007 | Sony VAIO GRX550 Notebook
Samsung X15 Notebook Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
