Question about Zebra Printer 140-751-00000
110xi111plus error code: warning ribbon in? what does that mean?
  • 53 Answers
That ribbon occures when you are set for thermal direct printing in the driver or printer and you should be set for thermal transfer in the driver in printing defaults off of the advanced tab and the printer needs to be set for thermal transfer in print method in the setup menu. thermal transfer is printing with black ink ribbon and paper and thermal direct is just chemicaly treated paper.
Posted on Jul 07, 2009
KENMORE OVEN 79047842403 ERROR CODE F14
The F14 error code indicates a loose connection (due to burned contacts and circuit board) between the touch panel and the electronic control (clock). The repair is to disconnect and inspect the end of the ribbon connector from the control and be sure it is connected properly. If the error code comes back the recommendation is to replace the touch panel and if the error code continues, replace the electronic control.
Remember to turn the power off and check the ribbon connector to the main control and see if there is any improvement
Jun 29, 2018 | Office Equipment & Supplies
Fe warning light
Fe error code means "Water Overflow Error". Check the upper level sensor of the machine.
Dec 22, 2013 | LG Washing Machines
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
good luck
Feb 27, 2010 | Whirlpool Ovens
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Wanting to find out what a warning light means any sites that show what the warning lights mean on a 1999 mitsubishi diamante
When the warning light comes on, your car generates an error code which is helped to diagnose the problem.
Got a local mechanic or most any auto parts stores (usually free) and ask them to scan your OBD2 port.
Their scanner will download the error code and then they can tell you what the code means and start you in the right direction to make repairs.
Nov 28, 2009 | 1992 Mitsubishi Diamante
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Error code EO -F2_
It means that your control panel went out and you need to replace it. Here is how if you want to try your self.
The control panel is not available as a complete part.
To replace the control or touchpad, pull the range away from the wall and disconnect the power to it. Remove the cover on the rear of the control panel. Remove the screws that hold the clock or control to the front wall of the control panel. These screws also hold the touchpad to the front of the control panel. The touchpad connects to the control with a ribbon connector and there is a locking tab holding the ribbon connector to the control. Lift the locking tab and unplug the ribbon.
Dec 18, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra Printer 140-751-00000 Logo
380 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
