Question about Sony Cyber-shot DSC-W70 Digital Camera
Access same as discribed in the problem
    Problem Solver:
  • 7 Answers
Buy one then you will have access to it
Posted on Jul 03, 2009
Opel Astra 2L 1994
Why in the world is this posted on Network & Wireless Adapters?
Post it in the correct automotive area and you will be more likely to get a good reply
Despite that, you will probably need to replace the mass air sensor. Shouldn't be too expensive.
Good Luck.
Nov 13, 2013 | Computers & Internet
I Discribed the Problem It would appear liteon gives **** poor Service
Don't install that software.
Instead, access: http://www.MajorGeeks.com
and search for "AShampoo Burning 6" software.
Download this _FREE_ software for creating/burning CD/DVD disks.
Install it, and use it on your LITE-ON burner.
Jan 23, 2011 | Computers & Internet
Game Boy Color Console: Could you please discribe colour dumps, sweeps, li...
Well it might be broken so my best bet would be to buy a new one then.
May 18, 2010 | Nintendo Game Boy Color Console
The heater core leaks and I was wondering what is involved in replacement
When the heater core is leaking in this particular car -- the dash assembly has to be removed to access the heater box assembly.. This job is long and you have to be patient. If you are going to take on this type of job I suggest that you take pictures as you go so you can refer back to them to reassemble the dash.. It would be a good idea to pickup a Haynes Manual which discribes in detail how to do this job.. Please note (make sure you disconnect the battery before you start working on the dash, this vehicle is equipped with air bags .. when you reconnect the battery later you may have an air bag light come on in your dash which will need to be cleared with a scanner, most repair shops now a days have one and it usaully costs about $100.00 to do this.. Good luck
Jan 14, 2010 | 2004 Toyota Solara
Front left leak
Red oil is usually Transmission fluid, if this is the case, the item you are discribing is likely the transmission cooler. If you can gain access to this area, you need to check the connections, as the may have just worked loose. Also check your transmission oil level to prevent any possible damage to the trans.If you cannot repair the laek with tightening the connections, then you will need to determine if it is the line or the cooler that is leaking and replace as needed.
Hope this is of some help.
Ed
May 08, 2009 | 2003 Pontiac Grand Prix
Hisense heat pump wont start cant find agent access to parts
I have some older AMANA parts books but I'll need the MFG number to look up anything. If you can discribe what it does I may be able to recomend a generic replacement
Mar 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
1991 honda accord
There is no access from under the back seat on your particular model. You are going to have to drop the gas tank to get to it. The nice thing is that the Honda's come with a fuel drain which you will see when you get under there. Drain the fuel and then you will have to drop the tank and have somebod hold the tank while you get up into the fuel pump area. The problem is probably not your fuel pump though, they do not go bad very often on these cars. I thought mine was bad until I hooked up direct power from the battery and it worked. Try replacing the main relay under the driver's side dash it is underneath a silver box which controls your cruise control. The relay will say MAIN with 12V underneat it. It is brown and grey. Hope this helps
Jul 30, 2008 | 1991 Honda Accord
Quasar TV access code for parental control
same problem as discribed on a Quasar sp2722 0000 didnot unlock the parental control
thanks
Feb 09, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Sony Cyber-shot DSC-W70 Digital Camera Logo
106 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
