Top view - behind left hand transmission end cover:
http://i40.photobucket.com/albums/e237/jd2694/Fatboy%20Pics/Drain-Plug-1.jpg
Bottom view:
http://i40.photobucket.com/albums/e237/jd2694/Fatboy%20Pics/Drain-Plug-2.jpg
SOURCE: oil drain plug
its not a plug its a hose look under the tank on the pipe side, look for the hose thats goes to the bottom frame rail (tube) thats the drain hopes this helps
Hi
It is located on the right side just under the oil tank ; if you follow the rudder hose that exits the rear right side of your oil tank it leads to the bottom of the frame under this is the oil plug. This hose has a plug clamped to the end of it or stuck into a prug that is welded to the frame.
After this unclamp and pull the plug to make sure that you have the dipstick out before pulling it loose.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Its at the back of crank box right hand side of bike attached to bottom of frame in a sprung clamp just before the softtail swingarm- black hose with a plug and hose clip
SOURCE: how to change oil for2007 heritage softail classic
The oil drain us usually a hose with a plug in it that is held by a clip on the frame. It us usually on the right hand side of the bike just behind and underneath the transmission side cover. Loosen the clamp and pull the plug out. The oil will run out of the tank. Replace plug and add new oil to the tank.
SOURCE: Where is the oil drain on the 2003 Heritage
on the right side of the bike where the swing arm and frame meet look for a 5/8" head drain plug pointing straight down that is your drain for the engine oil.
