i have a similar problem........the problem is in the heating unit underneath the oil container. if you remove it you will see the unit. in my case the problem was there was one of the contact points were plied back too far. once the contact point was plied back in place, the unit worked fine..
I have an Oster Cool Touch Deep Fryer. I want to clean the oil reservoir...is there a way to remove...
(More)
I have an Oster Cool Touch Deep Fryer. I want to clean the oil reservoir...is there a way to remove it from the unit so as not to immerse the fryer in water?
Need to change battery in Polder meat thermometer that is about 6 years old - I took out the screws...
(More)
Need to change battery in Polder meat thermometer that is about 6 years old - I took out the screws but I was not able to remove the plastic piece to see what type of battery I needed. Can you help?
