Question about GE Energy Star WCVH6260F Front Load Washer
Front load washer will not drain water - GE Energy Star WCVH6260F Front Load Washer
I had thesame problem with my from end loader, and the problem was that there was 6 month worth of change,crayons, and lint cloging up the drain valve. At the bottom of my washer there was a small cover, some are located higher than others but open it up, there will be a cover to turn,DO NOT OPEN untill you have something to catch the water that is going to rush out. Open slowly. then there will be a basket take out the basket clean it out and put everything back properly tighten the cover. And this should fix it!
Posted on Jul 29, 2009
    Problem Solver:
  • 9 Answers
Drain motor (or solinoid) is probably stuck or has something in it keeping it from opening.
HonestDan -eBay ID= Jerrycia95*
Posted on Jul 02, 2009
My front load washer do not spin
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out. If helped, pl say so.
Apr 01, 2013 | Frigidaire FAFW3801LW Front Load Washer...
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Washer does not go thru spinning cycle
On a Lg Front load washer if the water does not drain the machine will not go into spin. check to see if your machine is draining the water.. if not check you clean out.... But befor you open the clean out use the hose to drain water first or you will be flooded by the water.
Sep 13, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Sep 16, 2009 | GE WSXH208A Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
254 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
