Question about Sennheiser HDR 130 Consumer Headphones
I HAVE THE HDR130 WIRELESS WHICH I HAVE NOT USED FOR A WHILE. I HAVE LOST THE INSTRUCTIONS FOR WIRE HOOK-UP TO A FLAT SCREEN TV. COULD YOU LOCATE THIS INFORMATION AND SEND IT TO ME? IF YOU CAN NOT E-MAIL IT PLEASE MAIL IT TO J.WATKINS 425 RAVENSTONE DR. CHESAPEAKE, VA 23322. THANK YOU
    President:
  • 1,383 Answers
When you pur chse wi fi head phone u get 2 thing 1 head phone and other wireless outlet which connect with cable to TV .
Coonec *** to TV with cable in sound output jack of TV .
then switch on headc phone check its battery cell are ok/.
Posted on Jul 02, 2009
Need hook up instructions for ht 391 need help hooking up to a lg flat screen
Do you have a DVD player or receiver to hook the TV up to as well, along with the speakers? Most TVS do not have 5.1 surround "outputs" on their own but are used more like a monitor--
Jan 25, 2015 | LG Audio Players & Recorders
Want to hook up vizio sound bar
Follow the instructions that came with it, if lost l would Google the model number of the sound bar to locate the manual for use.
Dec 03, 2012 | Sanyo DP42849 42 in. HDTV
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
Lost the instructions to use Gigaware Pc Tv. Help to locate instructions how to use Gigaware Pc Tv
Hello, please follow this link to view the manual in pdf format:
Gigaware PC to TV Converter
Please remember hook it up before you turn on your computer.
You may also need to adjust your resolution down a little. Right-click on your desktop and click screen resolution to adjust the resolution
I hope you find this useful
Jul 07, 2011 | Computers & Internet
I have just hooked up set top box to Sharp TV CX5182 and need to re-tune it? Can you send me instructions please as I can't find my operators manual. Many thanks.
By set top box do you mean a digital tuner box? If so and your tv is a newer flat panal than more than likely you wont need it anymore. That tuner will be built in. If this is the case than hook your anntena up to the new tv and go to the menu to do an auto channel search. That should do the trick. If it is an older tv and doesnt have the tuner then hook up the box the way you hooked it up before IE if you used cable than hook it up with cable if you used it with Composite cables(RCA) than use those the reason is some of those boxes you have to set that part up in the settings and that disabled the other output so if you had it set for cable than hooked it up with Composite(rca) nada, nothing would show. Once you hook it up and you see it on the screen then your good to go simple channel search from there. Also if you use cable then your tv needs to be on channel 3 or 4 if you use Composite(rca yellow red and white) then your tv has to be on the input channel that coencides with what input is hooked to.
Dec 13, 2010 | Televison & Video
INSTRUCTIONS ON HOW TO hook up surround system to a flat screen t.v..tv is a sharp, and surround system isYamaha, and tv is connected to a dvd and vcr system
Use the Audio Output jacks Red/White from the Tv to the Tv Audio In on the Yamaha. If the audio out is being used from the tv now then go to Best Buy, Radio Shack and get a Y-adapter (rca jack type) with Single Male--Double Female. That will split off the audio coming out of the tv.
Dec 06, 2010 | Televison & Video
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
Don't know where to hook cable wire into my W4207-Flat Screen
Nice tv - but its a monitor, so there will NOT be a RG6 cable connection on the set. you have to provide a tuner to get signals OR use a cable box, sat box, etc.
May 04, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
Sennheiser HDR 130 Consumer Headphones Logo
372 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
