Question about Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook
Airport connection says Connection Timed Out.
Im using a macbook and trying to get onto a local wireless connection. It is unsecured and comes up one i turn the airport but i cant connect to it. It comes up ''Connection Timed Out.'' Ive never had that happen before. I am in range and have used the connection in the past. why cant i connect all of a sudden?
I don't think this is a problem with your macbook, it is probably a problem with the wireless router that is broadcasting the connection. Try restarting the router and connecting then.
Posted on Jul 04, 2009
I keep losing my wifi connection
try reseating the wireless card or airport card. if that doesnt work. turn off your wireless router and your macbook. leave off for 10 mins then turn on the router first then macbook. try to connect and see if that fixes the problem.
Dec 19, 2012 | Apple MacBook Air
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Macbook will not connect to wireless connection.
Try to use NetSpot app (it is free) http://www.netspotapp.com/
May 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Macbook 13.3" won't log in to wireless
You need to check your network card software your problem may lay there. I've seen this problem many times in the passed. I will install a wireless network card or software on someones computer and two days later it will not connect everything looks fine. No matter what I do it will not connect. Remove net software for the card or on board wireless reinstall and boom it works fine.
routers may need reset or configured off the internet or the start up cd. I take this a wireless router hooked to internet gateway. don't know not enough information you may need to tell me a little more. first try install of net-card software then set you working router to unsecure no pass word need see if you connect then change it to you wpa password protected.
Mar 20, 2009 | Apple aluminum 13-inch MacBook laptop-...
is it a airport used or a router? if so, have you tried to reset it?
Feb 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I have a macbook that I cant get to connect to my 2wire modem correctly
Make sure that the airport is on. Connect to your modem & type in the wireless password.
If still having problem joining the network, delete the keychain but make sure you only delete the keychain for 2wire by going to utilities then keychain access.
Oct 08, 2008 | 2wire (1000-000057-000) Modem
Can't connect!
First of all... Unplug the modem, unplug the Airport (WiFi router) and turn off the Airport connectivity in your MacBook.
After 5 full minutes... Plug in the modem.
Wait 2 full minutes... Plug in the Airport.
Wait 1 full minute... Turn on the Airport connectivity in your MacBook.
After all of that...
If you're still not back up and running and you're using an Apple Airport, open the Applications folder, open Utilities, open Airport Utility.
If you're using any other type of WiFi router, use the Network Diagnostics button that should show up in the web browser window when you try to go to any website.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Connecting Apple MacBook
Try turning off encryption on your router if it is on. Many times the macs can have an issue with encryption.
Sep 08, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
2,285 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
