Question about APC Smart-UPS 1400VA UPS System
APC 650 Pro not working properly.
The UPS is not supplying power to my computer and monitor when the 120V power is removed. It does supply power to a load when it is pluged in. I think the battery is ok. I checked it and it is 12.9 V. To check and see if It would work I connected a small lamp to the UPS and pushed the button to turn it on. Green light flashed on and off. and overload light, lights briefly, then green light comes on solid and the lamp lights. Lamp does not light unless UPS is plugged in. ThankYou, Richard
  • rhburdon1 Jul 02, 2009
    Yes, it has a "Replace Battery Led", but it is not on. I'm quite sure it is not the battery. The battery is about two years old and reads 12.9 volts. Turning on from a cold start, the green led flashes and test lamp lights, then the overload led flashes and the green led lights up solid and test lamp stays lit until 120V power is removed, and then test lamp goes out. Thanks for the reply. Richard
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Doesn't this UPS have a "Replace Battery " LED? (Icon is a battery with an "X" in the middle.) The 650 Pro is an older model and the life expectancy of the battery is 3 to 6 years.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
My question is how long is the battery inside your UPS? 5years ? coz sometimes you cannot just base on the voltage you measure on the batteries. dont forget about the current that is being supplied by the batteries maybe the battery current is too weak to handle your load. but if you are really sure that your battery is good. try to check the inverter circuit of your UPS. or send it to UPS service center if you dont know how to check electronics component.
Posted on Aug 14, 2009
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Apc 650 back-ups does not boot
try turning on the power connection
Mar 22, 2013 | APC Back-UPS Pro 650 UPS System
Apc ups not powering on
hi,
check the battery voltage. if it is bellow 11v this problem can occur. apc ups starts from its battery and then only it gos to mains supply. if ur battery is deeply discharged it will not power on. in this case u have to pullout the battery from ups and charge it using battery charger. if not works replace the battery.
Dec 17, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My APC350 backup ups has a overload when power is interupted with no load connected. The unit will start beeping but does not supply battery back up. The power supply to the battery shows 14.4 volts and...
It may still be supplying power but the surge arrestors were probably damaged by the surge. Go to apc.com choose support from the menu bar, they should be able to help or maybe even replace your unit.
Jun 06, 2010 | IBM APC Back-UPS Pro 350 (22P5090) UPS...
APC BACK-UPS PRO 1100VA 120V does not cold start.
When was the last time you replaced the batteries? These units will not start with old / failed batteries connected, or without batteries connected.
If you have a voltmeter, check the batteries. Your unit should have two batteries harnessed together. if you check the individual battery, you should see just over 13 volts, together should be around 26 volts. if you see less than 12.5 volts, that would be why the unit will not start.
You will have to replace the batteries if that is the case. Your BP1100 takes an RBC 7: moz-screenshot-1.pnghttp://www.refurbups.com/APC-RBC7-Compatiblemoz-screenshot.png
Apr 14, 2010 | APC Back-UPS Pro 650 UPS System
Problem with APC Pro 420
If the unit works ok on mains power, then it is the usually the batteries causing this, New battery i think you need.
Sep 17, 2009 | APC Back-UPS Pro 650 UPS System
Apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Feb 24, 2009 | APC Back-UPS Pro 650 UPS System
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
APC Smart-UPS 1400VA UPS System Logo
333 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
