Question about Maytag Refrigerators
Bad odor coming from underneath my fridge - Maytag Refrigerators
  • 2,418 Answers
This could be many things, from spilled milk to dust bunnys. Pull it & look under her for what may be the cause. Look for a drip pan that catches defrost water, pull that out and clean that. Repost I'll be back online tommarow.
Posted on Jul 02, 2009
Freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
HI, MY MCBR415S FRIDGE HAS AN ODOR I SIMPLY CAN NOT REMOVE..THIS FRIDGE HAS A DRAIN IN THE INSIDE AND IM GUESSING THIS IS WHERE THE ODOR IS COMING FROM. HOW CAN I CLEAN THIS?PLEASE HELP ..
This happened to me. I had to remove the screws on the bottom of the freezer lift the Plastic and clean underneath with vinegar. Then put a few boxes of opened baking soda for about a week you can also poor vinegar down the defrost drain tube.
May 11, 2011 | Refrigerators
Freezer has a bad odor but its not coming out through the inside. I checked if has a pan underneath but it doesn't or at least I can't see it.
You will find that mould has grown in the defrost water drain.
Pour warm soapy water down the drain untill it is clear
Then to remove the lingering odour place an open saucer of vanilla in the fridge to absorb the smell
Mar 29, 2011 | Refrigerators
There is a bad odor coming out of the fridge when you open the door, everything else works fine.
Is it a food odor or metallic? Try crushing up some charcoal into a powder and place in the fridge in an open dish.
Feb 23, 2011 | Refrigerators
I have an oder in my fridge and freezer. no spoilage in there. both the fridge and freezer has an odor and gets into all the food. cleaned it out, shut it off for a day and still i have it. would would...
ok.its a very common issue.just tie a handful of baking soda in a soft cloth and keep such1 or 2 pads in both the freezer and fridge section.this will absorb all the bad odor within a day or two.once the odor is gone throw the pas away.repeat this once in three months to prevent the bad odor from coming again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Amana ABB1927DE Bottom Freezer...
Bad odor when you open the doors of the refrigerator
The odor is coming from your drain pan under your evap coil. This is very ahrd to get to. They make a product that you can set in you fridge and let it run and it will take out odors. Google Refrigerator odors and it will take you the site that will ahve the product. rus
Nov 09, 2009 | Hotpoint HSS25GFP Side by Side...
Odor
Could you possibly have a dead rat under there? I know this sounds gross, but they love to hide in the electronics. (Sorry). Anyway, your drip pan may sit on a small bracket type piece that isn't heavy at all. It can sometimes get misplaced, causing the fridge to leak because it's out of place. If you can get a flash light, you should be able to see where it's placed and you should be able to remove and clean it out. I put Mr. Clean in mine when it gets an odor and when water hits it, the solution cleans the odor, but you can clean it and replace it. I hope this helps!
Aug 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
There is a bad odor blowing out from under my Whirlpool side-by-side refigerator. How do I fix it?
Hi
Odors in the refrigerator can come from many different sources. Spoiling food, spilled milk, open food. Often a really good cleaning out with an ammonia cleaner can help or with a baking soda water mixture.
But, sometimes an odor can "permeate" into one of the plastic parts found inside the fridge, crisper pans, door liners, shelf supports. Even after you have found the spoiling food, removed it, cleaned the fridge up.....sometimes another plastic part will pick up this odor and continue to give the odor back off. A few things that can help with this type of an odor, place one these inside the fridge section:
- box of baking soda
- dish of coffee grounds
- open slices of bread
The bread trick can be used to effectively to remove odors. Just throw a slice or two onto one of the shelves in the fresh food compartment, leave the bread slice(s) in there for 12-24 hours -no longer- and then throw the bread out or I throw the bread outside for the birds to eat. When bread goes stall, it will **** in odors very well. Because the air inside the refrigerator is blown between both sections, this will help the fridge and freezer sections. Do this for about a week and you should notice a big change in the odor problem :-)
A really bad odor problem. Sometimes something like milk or juice is spilled inside the fridge. The liquid can run under the plastic edge breakers and get into the insulation. This can be very difficult to clean and may require a service call to have the old insulation removed and replaced with new insulation in that section.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Odor coming from back of fridge
This is very unusual, most of the time when I get complaints about odor it's form the inside of the cabinet. This should be easy enough to solve though. The odor is likely from dust accumulated underneath, or from something in the drain pan. If the unit has visible fiberglass insulation underneath you should replace it with new because, even if the source of the odor has been removed, the insulation can still contain it.
Unplug the refrigerator, take off the kick plate and rear cover. Clean and vacuum the entire under- carriage, condenser, fan, and condensation evaporator tray.
Be gentle with the components though, especially the capillary tube ( a pipe about the size of a 14 gauge copper wire )
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
146 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
