Question about Kitchen Ranges
Ignitor won't spark
Magic Chef model 34MN-3TKVW-EV (@15 yrs old). I replaced all 4 burners, (removal and replacement was easy thanks to advice from this board). After replacing all burners, only the front 2 burner's ignitors spark. The back 2 do not. All four burners are feed by 4 independent wires (orange) and there are no other wires going to the burners. Here's the wierd part, when the one wire to one of the back burners touched metal, i got spark at the other back burner. So obviously there is a grounding problem. Does the body of the burner create the ground required for the ignitor to spark? I am not quite sure how to address the grounding issue. The burners work, I can use a candle lighter to light them, but it's not right. Just drives me a little crazy. Any suggestions would be appreciated. Thank you in advance.
    President:
  • 1,723 Answers
Look at the front ignitors that work and look at how they ground. Then, set the back ones up the same way. Make sure the 'arc gap' is the same too.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
The 4 burners work, but the oven does not work on my Model 3187 VUV magic Chef.
heatman101
Oct 12, 2010 | Magic Chef 9112 Gas Double Oven
I have a Magic chef gas range top. I dont have a model # but the unit is approximatly 10 yrs old. It recently started to tick as though one of the ignitors is on. What would cause this condition?
This is caused by one or more of the burner switches going bad. Sometimes brought on by water being spilled into the control area or just buildup of grease and dirt. If they are not overly expensive I recommend my customers to have all 4 replaced while it is apart since all are the same age. It could also be a shorted wire or faulty spark module. (I check for a bad switch, Then wires. If these check out the module is all that is left.)
Eric
Aug 17, 2010 | Magic Chef Ovens
Magic Chef gas range ignitor continually clicking
One of the burner control switches is shorted. If they are not overly expensive I replace all 4 while it is apart.
Eric
Feb 23, 2010 | Kitchen Ranges
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven not lighting
Sounds like the ignitor in the oven is weak and not building up enough resistance to the gas valve to allow gas to the burner. I would replace the ignitor if it is more than 3 or 4 yrs. old.
Oct 05, 2007 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
203 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
